How does Pihole generate the stats at the dashboard from its data sources (detailed code desired)
Please someone, give me a url, or any alternative, where I can find a copy of the queries, which are used by the pihole dashboard. AND no I am not interested in doco links unless they provide all the queries details (query), used by pihole for each individual query for the reporting area within the dashboard. I just would like to see each query by its individual details. Thanks.
http://pi.hole/admin/queries.php
Thanks for that, but Sorry I am asking for each query code detail and not the end display via the web gui. Where is each query detail not the result of each query
In addition to the long term database at /etc/pihole/pihole-FTL.db, query details are in /var/log/pihole.log (for today) and /var/log/pihole.log.1 (for yesterday). Each reply, response, etc. In plain text.
Let me explain a bit further...
In the query to construct "Top Permitted Domains" you are selecting "queries" records with statuses of 2 or 3.
How about the other "Top" selections on the dashboard, do they involve filtering on the "status" column in the "queries" table?
Anyone able to answer the above question?
It's all in the source code. The sql queries against the database are put together piece by piece and use a lot of variables to be flexible and reusable.
If your looking for the raw data (DNS is binary) thats communicated on the line when doing a DNS query (not including the anwser):
C:\>nslookup -type=a pi-hole.net.
Server:  ph5.dehakkelaar.nl
Address:  10.0.0.4
Non-authoritative answer:
Address:  192.124.249.118
pi@ph5:~ $ sudo tcpdump -lnqtX dst $(hostname -I) and udp port 53
tcpdump: verbose output suppressed, use -v or -vv for full protocol decode
listening on eth0, link-type EN10MB (Ethernet), capture size 262144 bytes
IP 10.0.0.11.59099 > 10.0.0.4.53: UDP, length 39
        0x0000:  4500 0043 0ce7 0000 8011 19b5 0a00 000b  E..C............
        0x0010:  0a00 0004 e6db 0035 002f 8196 0001 0100  .......5./......
        0x0020:  0001 0000 0000 0000 0134 0130 0130 0231  .........4.0.0.1
        0x0030:  3007 696e 2d61 6464 7204 6172 7061 0000  0.in-addr.arpa..
        0x0040:  0c00 01                                  ...
IP 10.0.0.11.59100 > 10.0.0.4.53: UDP, length 29
        0x0000:  4500 0039 0ce9 0000 8011 19bd 0a00 000b  E..9............
        0x0010:  0a00 0004 e6dc 0035 0025 532c 0002 0100  .......5.%S,....
        0x0020:  0001 0000 0000 0000 0770 692d 686f 6c65  .........pi-hole
        0x0030:  036e 6574 0000 0100 01                   .net.....
If thats not it, tell us in more details what specifically your looking for ?
I guess it's something like...
if (isset($_GET['topDomains']) && $auth)
	$limit = "";
	if(isset($_GET["from"]) && isset($_GET["until"]))
		$limit = " AND timestamp >= :from AND timestamp <= :until";
	elseif(isset($_GET["from"]) && !isset($_GET["until"]))
		$limit = " AND timestamp >= :from";
	elseif(!isset($_GET["from"]) && isset($_GET["until"]))
		$limit = " AND timestamp <= :until";
	$stmt = $db->prepare('SELECT domain,count(domain) FROM queries WHERE (STATUS == 2 OR STATUS == 3)'.$limit.' GROUP by domain order by count(domain) desc limit 20');
	$stmt->bindValue(":from", intval($_GET['from']), SQLITE3_INTEGER);
	$stmt->bindValue(":until", intval($_GET['until']), SQLITE3_INTEGER);
	$results = $stmt->execute()
... to generate a sql query for the top clients table on the dashboard. If you want to repeat it manually you have to replace the variable with the values the dashboard inserts (eg for 24h)
sqlite3 /etc/pihole/pihole-FTL.db 'SELECT domain,count(domain) FROM queries WHERE (STATUS == 2 OR STATUS == 3) AND timestamp >=strftime("%s", "now")-86400 GROUP by domain order by count(domain) desc limit 20'
I am still having problems with the "Top Clients (total)" table. The number of records in the sqlite database does not match what is being displayed on the dashboard. It looks like the queries table is read over a period of a day (without any status filtering), does anyone know how often the data is refreshed on the admin.php page?
Thanks for all your help so far.
I believe most on the dashboard (only showing last 24 hours) is derived from the logs.
And the long term data is pulled from the database ... correct me if am wrong ?
About update/refresh period:
The long term database shows all queries (to the limit of your configuration parameter MAXDBDAYS, default = 365). On startup, FTL reads the most recent 24 hours (the default setting) of history from the database and uses that to populate the dashboard.
The dashboard always shows the most recent 24 hours. I haven't checked the code, but I recall it's updated in 10 minute intervals.
Ok, it's more complicated than I thought...
The api_db.php I linked above (and also the code example I showed later) is just for querying "long-term database" and getting the "Top Lists" from there.
For the Dashboard it's different.
I walked through the script as far as I could but didn't succeed.
index.php contains an element with id="client-frequency
This triggers in index.js the function ''updateTopClientsChart''
which sends a request to the API with get api.php?summaryRaw&getQuerySources&topClientsBlocked. Interesting part is the getQuerySource
api.php doesn't know getQuerySource but references api_FTL.php
In api_FTL.php PHP sends a "top-clients" request to FTL
sendRequestFTL itself is defined in FTL.php
https://github.com/pi-hole/AdminLTE/blob/b86e4a3178e46cef9fc738c6a0fb8d0ef0ff2fbc/scripts/pi-hole/php/FTL.php#L24
FTL src/api/request.c calls a function getTopClients trigged by top-clients request
https://github.com/pi-hole/FTL/blob/3d7c095cb10a1b692c80dd28f6051dea91d45baa/src/api/request.c#L54
getTopClients is defined in /src/api/api.c
https://github.com/pi-hole/FTL/blob/3d7c095cb10a1b692c80dd28f6051dea91d45baa/src/api/api.c#L349
And here it got complicated and I stopped (for now). Feel free to continue and let us know :slight_smile:
It's 10 minutes for some graphts
https://github.com/pi-hole/AdminLTE/blob/b86e4a3178e46cef9fc738c6a0fb8d0ef0ff2fbc/scripts/pi-hole/js/index.js#L262
but the tables are updated every 10 sec
https://github.com/pi-hole/AdminLTE/blob/b86e4a3178e46cef9fc738c6a0fb8d0ef0ff2fbc/scripts/pi-hole/js/index.js#L659
