Good afternoon,
I am opening this Topic, because i have an Idea in Mind, but i cant tell if "Groups" are actually designed for that specific kind of Idea. You see, i am running windows 10 on all of my Machines, since its the latest OS by Microsoft, and i kinda rely on having Windows as an operating System. The Thing is though, that i dislike Microsofts Behavior in regards of pushing Updates on my Computers without asking for my consent. Here is what i did: i blocked every Domain that could make my OS download Updates automaticaly. And in the past i simply had a txt.file to quickly copy and paste the domains either into the blacklist or the whitelist, so i could either open or close the floodgates. But this doesnt work on the later updates for Pihole anymore, so i searched for a workaround. Later i found out, that you can add Domains to Groups, so you can tell the pihole to either block or Unblock added Domains the convinient Way. So i added the right Domains to a Group called "Updates"..... and here is the Problem: no matter what i do, the Domains remain either blocked or unblocked, no matter what PCs i add to the group, or what the switch says in the group-settings. its almost as if the pihole totaly ignores that i created a group. do i miss something? i read through some tutorials i found here and elsewhere, but nothing works.
best regards.
