How do I monitor Pi-hole with monit?
I would like to monitor Pi-hole through Monit. I'm already monitoring Domoticz through Monit. Can anyone tell how to do this?
In an older topic @Sjonnie mentions he has a solution. @Sjonnie can you DM me your solution or Monitrsc?
Thx!
Good topic :slight_smile:
I think I would do the checks via port monitoring:
pihole-FTL: port 4711 (tcp)
lighttpd: port 80 (tcp)
dnsmasq: port 53 (tcp), port 67 (udp)
dhcpcd: port 68 (udp)
Hi @vmb
I thought I'd best post a reply here so others might benefit from the terrible solution I used.
I edited the file /etc/monit/monitrc and added a few lines. The more knowledgeable users will create separate files for each service they want to monitor but I did not get that to work.
This is what I added at the end of the file to monitor Domoticz and the (core) components for Pi-hole:
## Added to monitor the Domoticz service
  check process domoticz with pidfile /var/run/domoticz.pid
  start program = "/etc/init.d/domoticz.sh start"
  stop  program = "/etc/init.d/domoticz.sh stop"
## Added to monitor Pi-Hole
  check process pihole-FTL with pidfile /var/run/pihole-FTL.pid
  start program = "/etc/init.d/pihole-FTL start"
  stop  program = "/etc/init.d/pihole-FTL stop"
## Check status of DHCP
  check process dhcpcd with pidfile /var/run/dhcpcd.pid
  start program = "/etc/init.d/dhcpcd start"
  stop  program = "/etc/init.d/dhcpcd stop"
## Check dnsmasq
  check process dnsmasq with pidfile /var/run/dnsmasq/dnsmasq.pid
  start program = "/etc/init.d/dnsmasq start"
  stop  program = "/etc/init.d/dnsmasq stop"
## Check Pi-Hole web interface
  check process lighttpd with pidfile /var/run/lighttpd.pid
  start program = "/etc/init.d/lighttpd start"
  stop  program = "/etc/init.d/lighttpd stop"
HTH
Greetz,
Sjonnie
PS. If other have additions or better solutions please post them in this thread! :slight_smile:
@Sjonnie: thx for your quick answer and solution. Happy with it!
I'm a beginner with Raspbian, so I'm not sure if I can help you very much.
I have one addition to the script to monitor Domoticz. From the Domoticz wiki I pasted these lines. These lines work perfect for me...
if failed
url http://127.0.0.1:8080/json.htm?type=command&param=getversion
and content = '"status" : "OK"'
for 2 cycles
then restart
if 5 restarts within 5 cycles then exec "/sbin/reboot"
Is it possible to add something like that to the lines regarding Pi-hole? Whats your opinion on this?
Thx/Bedankt!
Hi @vmb,
I believe the "if failed" statement is not necessary for the services mentioned. It might be needed for the web service but I am not sure. Maybe a more knowledgeable user might enlighten us :wink:
Truth be told: Domoticz and Pi-Hole run like a charm on my RPi3. I haven't looked at the logs recently but I think all is well. You might want to play around with the settings in monitrc for a bit and let us know what you have found out.
You're welcome / Blij dat ik je kon helpen :slight_smile:
Greetz,
Sjonnie
You should not rely on pid files, they are not reliable. A daemon/process can crash, without deleting its pid file.
Better to check for the real existence (is it running) of the process or for its (open) ports.
@Sjonnnie: Will do.
Thanks for you addition (regarding your 'if failed' statement), think your right. I looked in the adminpage of monit, overthere I saw that Monit itself check the state of the process every 30 seconds. So thats good enough for me.
Also agree to what you say. It works like a charm over here. Yesterday evening I installed Pi-hole on my Pi3 with Domoticz/Monit and Pivpn. All these programs work great. No problems and Pi stil running smooth!
Thanks again for your help, will report back later.
Hi @mibere thanks for your comment.
Do you have any suggestions how to translate these checks of the processes and ports into Monit-language?
This is my solution for lighttpd:
cd /etc/monit/conf-enabled
sudo nano lighttpd
check host lighttpd with address 127.0.0.1
  start program = "/etc/init.d/lighttpd start" with timeout 20 seconds
  if failed port 80 type tcp with timeout 5 seconds for 2 cycles then restart
  if 4 restarts within 5 cycles then unmonitor
sudo /etc/init.d/monit restart
with these settings in /etc/monit/monitrc
  set daemon 120            # check services at 2-minute intervals
    with start delay 60     # optional: delay the first check by 60-seconds (by
#                           # default Monit check immediately after Monit start)
See this feature request
Here my other configuration files
check host dhcpcd with address 127.0.0.1
  start program = "/etc/init.d/dhcpcd start" with timeout 20 seconds
  if failed port 68 type udp with timeout 5 seconds for 2 cycles then restart
check host dnsmasq with address 127.0.0.1
  start program = "/etc/init.d/dnsmasq start" with timeout 20 seconds
  if failed port 53 type udp with timeout 5 seconds for 2 cycles then restart
check host pihole-FTL with address 127.0.0.1
  start program = "/etc/init.d/pihole-FTL start" with timeout 20 seconds
  if failed port 4711 type tcp with timeout 5 seconds for 2 cycles then restart
Great, thanks a lot!
Below one is missing UDP as initially, the clients will talk UDP first:
And for below one, the proper port is 67 UDP (server) and not 68 UDP (client):
All those heuristics only test the IP stack.
Thats ok but not a real test to check if the services/daemons are still working/responding as should.
Proper heuristics for lighttpd would be to access a web file.
Proper heuristics for dnsmasq would be to do a DNS query.
Some examples here:
The dhcpcd on my system is just listening on UDP 0.0.0.0:68.
0.0.0.0:67 UDP is dnsmasq.
dnsmasq does the DHCP server bit for Pi-hole.
dhcpcd does the DHCP client bit (suppose Pi-hole were configured to acquire IP through DHCP).
netstat -nltup
And this:
$ man dnsmasq
DNSMASQ(8)                                               System Manager's Manual                                              DNSMASQ(8)
NAME
       dnsmasq - A lightweight DHCP and caching DNS server.
And:
$ man dhcpcd
DHCPCD(8)                                              BSD System Manager's Manual                                             DHCPCD(8)
NAME
     dhcpcd — a DHCP client
