instead of lighttpd
I expected to see less adds on apps and websites
Not seeing and reduction in adds on apps and websites.
I finally seemed to have my pi-hole set up, i logged in to the pi-hole page through the established IP address and adjusted the DNS on the devices on my network. I also did on the wireless router. It seems to be doing something according to the web page but I am not noticing and difference in advertisements on websites. Did I miss something?
Seems to be running according to website for the pi-hole
