How do i install v5 pihole on rpi4?
how do i install v5 pihole on rpi4?
like simple way of sudo apt-get install pihole-v5?
rip4 8gb bullseye
If you want a simple way to install Pi-hole, you can install Pi-hole v6.
If you really want Pi-hole v5, the easiest way is to use our docker image. The last v5 tag was pihole/pihole:2024.07.0.
:pensive_face: sudo apt-get install pihole-v5
dunno what docker is n dont wanna know😔.
no one could make a repo for sudo apt-get install pihole-v5 , with unbound. if u knew how, id make a github repo to do so.
i just know how to use pihole n unbound but dev build is giving me complications with device names.
Why don't you try and fix the problem rather than falling back to an old version of the software?
What is the problem you are having?
I don't use PiHole for DHCP so can't help with that, sorry.
When I have had issues with hostnames not displaying or the wrong hostname showing, clicking 'Flush Network Table' immediately followed by 'Restart DNS Resolver' usually fixes it.
I did this several times. no go. pihole is not issuing hostnames to 4 devices. i dont get it and why it isnt.
