How do I change my "icon"?
Annoyingly I am in another forum which uses the same engine but they have different things in different places.
Like the theme. Here it is under one menu. On the other one it is under another.
The other one I went into settings and set the icon. Here I can't find the settings for me.
Thanks.
Found it!
(Typically after I asked)
I can't mark this as SOLVED.
Sorry. Saw it after I posted it.
