Hello Pi-Hole Team,
You are doing an amazing job with the pi-hole.
I have a question as to how can I run pi-hole on a docker container?
So far I was able to host the pi-hole on a macvlan so that I can assign host network to the pi-hole.
However, it wouldn't let me connect to it as I need to have password specified.
If I am hosting docker-compose.yml file on linux vm then I can.
But the way I am doing using macvlan it won't, since it's getting image pihole/pihole:latest directly.
So is there a way I can modify the password?
┌──(kali㉿kali)-[~/pihole]
└─$ sudo docker run -itd --rm --network newpihole \
--ip 10.5.5.106 \
--name pihole pihole/pihole:latest
c562ff90*********************************c7e0b43772986a014f695245612419
Regards,
