How Can I completely block Internet from Pi Hole via DNS to a specific device
Block the root domain as a wildcard for that device only.
Make a new group in the Group Management tab, assign only that client to the new group, and assign the new blacklist entry only to that group.
Thanks For replying back can you please send the screenshot of block the root domain as a wildcard
Enter this as a regex domain blacklist entry:
Thanks, but it did not work
Is there any thing else that I can do
I'm not good with regex,
but I think
should suffice
or
but that last one just matches every character.
Dont give the device a gateway/default route.
Can do that via DHCP.
pi@ph5b:~ $ ip route show default
default via 10.0.0.1 dev eth0 src 10.0.0.4 metric 202
Thank you so much for your support. It finally worked!
