How block Netflix and Co?
Hello,
which domains are necessary to block (streaming)
Netflix
Amazon Prime
Disney+
i have try this here:
but dont work
thx
thx for the link.
try this, but will not work
Perhaps it is not possible to block my FireTV Stick with Prime and Netfix.
have a nice day.
try ' (\.|^)netflix\.com$'
These are the domains I put in whitelist to make sure Netflix is accessible. If you put them in blacklist, probably you'll be able to block Netflix.
dockhand .netflix.com
appboot .netflix.com
nrdp.nccp .netflix.com
secure .netflix.com
movies .netflix.com
movies1 .netflix.com
movies2 .netflix.com
movies3 .netflix.com
customerevents .netflix.com
nmtracking .netflix.com
presentationtracking .netflix.com
api-global .netflix.com
api-public .netflix.com
meechum .netflix.com
leia .netflix.com
athena .netflix.com
hydra .netflix.com
jira .netflix.com
ichnaea .netflix.com
ichnaea-web .netflix.com
ios.prod.ftl .netflix.com
*.prod.http1 .netflix.com
ios.prod.cloud .netflix.com
mobile-ixanycast.ftl .netflix.com
msg .netflix.com
cache .netflix.com
www.eu-west-1.prodaa .netflix.com
push.prod .netflix.com
beacon .netflix.com
help .netflix.com
