I expected to see host name resolution after applying the configuration proposed on this help page: Fritz!Box (EN) - Pi-hole documentation .
Hostnames are not resolved
for fritz + pihole hostnames, conditional forwarding only helps if two things match what the fritz is actually using.
check:
fritz.box, sometimes something custom)after changing that, flush the pihole cache (pihole restartdns or restart FTL) and recheck a client with nslookup some-hostname. if the debug token still shows CF off or the wrong domain, that is usually why the Network table stays on IPs only.
Thank you for your contribution. Unfortunately, that did not fix the issue.
The Fritz Box has been configured as follows:
pihole networkflush and pihole reloaddns commands, below is the result for the nslookup command:sharedbits@pihole:~ $ nslookup my_hostname
Server: 192.168.1.7
Address: 192.168.1.7#53
Non-authoritative answer:
Address: 192.168.1.110
Address: fdfa:5b8a:eee9:0:7139:aa85:4ad3:388c
Address: fdfa:5b8a:eee9:0:aedf:175b:c99a:935a
Debug token states:
revServers = [
"true,192.168.1.0/24,192.168.1.254,fritz.box"
] ### CHANGED, default = [ ]
[dns.domain]
name = "lan"
local = true
I believe this is correct as well.
Do you have any additional idea?
ah wait looking at that nslookup you posted, hostname resolution is actually working. my_hostname.fritz.box is answering from 192.168.1.7.
what usually looks "broken" after that is the Network overview still showing bare IPs. that table is picky about the local domain name matching.
you've got revServers on fritz.box, but dns.domain.name is still "lan". try setting dns.domain.name to fritz.box (same string as the CF domain), restart FTL, then refresh Network. for me the Overview only starts showing names once those two match.
if you mainly care about nslookup/ping by name, you're already good. the Network page is the laggy part.
Maybe useful to know :
Sometimes it takes a short period for the hostnames to appear correctly!
I have experienced this the last time I was adding a lot of hostnames at the same time in the Local DNS Records settings ![]()
Thank you @nero355 and @nite_route for the advice!
I got frustrated and in parallel of the suggestion to change the dns.domain.name from lan to fritz.box, I also started using the Pi-hole as a DHCP server which, obviously, instantly solved the issue. However, I guess I did not properly configure it since at lease renewal, none of my devices were able to reach the Internet anymore. My guess is that I didn't properly advertised the DNS server. Frustrated again, I disabled it and to my surprise the names remained in place!
So I guess issue fixed, but I can't tell whether it was because of the waiting of the domain name change.
