Can you add the PiHole hostname to the Teleporter Export filename?
Something like this?
pi-hole-HOSTNAME-teleporter_DATETIME
I run two and it would be helpful, managing configuration backups without manually renaming the .tar.gz file.
Thanks
Thanks
That sounds like a good thing to have.
Simple enough!
Implemented in v5.1
