Domain Name System (DNS) names are "case insensitive". This document
explains exactly what that means and provides a clear specification
of the rules https://datatracker.ietf.org/doc/html/rfc4343
Do you, by any chance, have some screenshots for us? I went through the code (rather quickly TBH) and didn't see any places where we do a conversion to lower-case for client hostnames. But, yes, we definitely do this for domains so depending on if you see the hostname as a client descriptor or as a requested domain, differences in capitalization are actually expected.
Once we have more information, we can go and take a closer look again.
Any updates on this? I'm having the same issue after upgrading to V6 and find it very annoying. Being able to see the case the way I enter it makes it much more readable and used to work fine in V5.
E.g: Bobs-MBP vs bobs-mbp, LivingRoomATV vs livingroomatv
But…
That’s not how the DNS protocol works ?!?!
Have you ever typed in any url in your browser with both upper and lower case letters ?!
I am guessing you have not and you will never need to either…
