The issue I am facing:
In Home app on iPhone, devices that are linked to Homebridge often will show as not responding for periods of time. I’ve narrowed it down to when Homebridge has in its logs unable to check for updates, just the user here had (except all of mine are timeout errors). Running npm install of any plugin in terminal takes minutes to hours to do, sometimes working, other times not.
I’ve changed the configuration of npm to use HTTP instead of HTTPS and set Strict-SSL to false, for both local and global. The issue remains.
nslookup as suggested in the link about also returns results, so it’s not blocked. Also disabled DOH and attempted it, same result - takes forever or times out in Homebridge.
Details about my system:
- Raspberry PI 4, with standard image.
- PiHole
- Homebridge
- Cloudflared DOH service
- uses Cloudflared to return DNS requests. Configured using the PIHole guide.
Any help would be appreciated.
