Just noticed that my /var/log/openvpn.log had a size of 188 MB. This is caused by my OpenVPN monitoring (every 3 minutes) with monit:
check host openvpn with address 127.0.0.1
start program = "/etc/init.d/openvpn start" with timeout 20 seconds
stop program = "/etc/init.d/openvpn stop"
if failed port 443 type tcp with timeout 5 seconds for 2 cycles then restart
if 4 restarts within 5 cycles then unmonitor
This leads to many
Thu Apr 19 21:41:45 2018 TCP connection established with [AF_INET]127.0.0.1:51008
Thu Apr 19 21:41:45 2018 127.0.0.1:51008 Connection reset, restarting [0]
Thu Apr 19 21:41:45 2018 127.0.0.1:51008 SIGUSR1[soft,connection-reset] received, client-instance restarting
messages in /var/log/openvpn.log, every 3 minutes.
By default OpenVPN has no logrotate - but we should enable it:
$ sudo nano /etc/logrotate.d/openvpn
/var/log/openvpn.log {
compress
delaycompress
missingok
daily
notifempty
rotate 2
copytruncate
create 600 root root
