Hallo,
seit heute morgen kann ich das Webinterface von Pi Hole nicht mehr aufrufen.
Wenn ich über den Browser "192.168.0.10/admin/" eingebe, erhalte ich daraufhin immer folgende Meldung:
Die Website ist nicht erreichbar
192.168.0.10 hat die Verbindung abgelehnt.
ERR_CONNECTION_REFUSED
Hier das Protokoll:
dietpi-launcher = All the DietPi programs in one place.
dietpi-config = Feature rich configuration tool for your device.
dietpi-software = Select optimized software for installation.
htop = Resource monitor.
cpu = Shows CPU information and stats.
root@DietPi:~# service lighttpd status
● lighttpd.service - Lighttpd Daemon
Loaded: loaded (/lib/systemd/system/lighttpd.service; enabled; vendor preset: enabled)
Active: failed (Result: exit-code) since Sun 2018-12-09 13:41:5
0 CET; 12min ago
Process: 994 ExecStart=/usr/sbin/lighttpd -D -f /etc/lighttpd/lighttpd.conf (code=exited, status=255)
Process: 954 ExecStartPre=/usr/sbin/lighttpd -tt -f /etc/lighttpd/lighttpd.conf (code=exited, status=0/SUCCESS)
Main PID: 994 (code=exited, status=255)
Dez 09 13:41:50 DietPi systemd[1]: lighttpd.service: Failed with resu
lt 'exit-code'.
Dez 09 13:41:50 DietPi systemd[1]: lighttpd.service: Service hold-off time over, scheduling restart.
Dez 09 13:41:50 DietPi systemd[1]: Stopped Lighttpd Daemon.
Dez 09 13:41:50 DietPi systemd[1]: lighttpd.service: Start request re
peated too quickly.
Dez 09 13:41:50 DietPi systemd[1]: Failed to start Lighttpd Daemon.
Dez 09 13:41:50 DietPi systemd[1]: lighttpd.service: Unit entered fai
led state.
lt 'exit-code'.
peated too quickly.
lt 'exit-code'.
root@DietPi:~# service lighttpd restart
Active: failed (Result: exit-code) since Sun 2018-12-09 14:00:0 6 CET; 8min ago
Process: 1572 ExecStart=/usr/sbin/lighttpd -D -f /etc/lighttpd/lighttpd.conf (code=exited, status=255)
Process: 1562 ExecStartPre=/usr/sbin/lighttpd -tt -f /etc/lighttpd/lighttpd.conf (code=exited, status=0/SUCCESS)
Main PID: 1572 (code=exited, status=255)
Dez 09 14:00:06 DietPi systemd[1]: lighttpd.service: Failed with resu
lt 'exit-code'.
Dez 09 14:00:06 DietPi systemd[1]: lighttpd.service: Service hold-off time over, scheduling restart.
Dez 09 14:00:06 DietPi systemd[1]: Stopped Lighttpd Daemon.
Dez 09 14:00:06 DietPi systemd[1]: lighttpd.service: Start request re
peated too quickly.
Dez 09 14:00:06 DietPi systemd[1]: Failed to start Lighttpd Daemon.
Dez 09 14:00:06 DietPi systemd[1]: lighttpd.service: Unit entered fai
led state.
lt 'exit-code'. root@DietPi:~#
Also scheint es irgendein Problem mit lighttpd zu geben.
Ich bin leider kein Experte im Bereich Linux und hoffe ihr könnt mir helfen.
Auf dem Raspberry nutze ich DietPi.
Besten Dank bereits für die Hilfestellung!
Gruß!
