I am just curious how I can see the individual host names using this router. With my Gargoyle router I was able to change the dnsmasq settings (method 2) and it worked flawlessly. However, the Synology router doesn't have the same options. I know I could set the Pi-Hole as my DHCP server but I would rather let my router handle it. I am looking for guidance from anyone who is familiar with this router
When setting the router primary DNS to point to the Pi-Hole I only see the router IP and not the clients connected to the router (which was expected). Is there a way to see the various clients (without having to manually set each client up)? Conditional forwarding? Ability to SSH into the router to change some setting?
