Help with admin website
Hello friends! I hope you’re doing very well, I pretty desperately need your help as I am very new to all of this! I believe I’ve set everything else up correctly including the static ip reservation, the actual setup, and everything else, but I’m hung up on this one problem! I’ve been trying to toubleshoot and sift through topics and nothing as quite worked.
To be able to access the Pi-Hole admin Webpage.
  • debian dietpi
  • Raspberry Pi 4b
When I try to go to the provided admin webpage (http://192.168.0.12/admin) it shoots a “could not connect to the server, NSURLErrorDomain ”error!
https://tricorder.pi-hole.net/OK1RKA7R/
Thank you so very much!! <3
Your log shows Pi-hole is using custom ports for the web server:
[✓] tcp:0.0.0.0:8089 is in use by pihole-FTL
[✓] tcp:0.0.0.0:8489 is in use by pihole-FTL
These ports were not changed by Pi-hole. They were manually added/changed.
You can access the web interface using one of the links below:
