Help with a SQL Query - Client Hostname
Good evening, I’m new here and have been using Pi-hole for a few days in my production environment. We replaced pfBlockerNG with it because the latter had issues with unbound functioning in pfSense, which I believe might have been due to the number of requests or some other unidentified bug by Netgate.
Anyway, I’d like some help regarding the logs, as I noticed I have two options:
  1. Through /var/log/pihole.log
    or
  2. A SQL query on the database located at /etc/pihole/pihole-FTL.db.
The first option doesn’t work well for me because I can’t retrieve my hostname, only the IP address and link.
I believe the second option will be more viable since I want to extract the log in the same way the system displays it in the "Query log" menu (date, domain, and client with resolved hostname). The problem is that I couldn’t figure out the SQL query that would help me achieve this.
As I use Graylog to store my data, my plan is to create a shell script that performs this SQL query and writes the results to a file periodically (once a day, for example). Then, I’ll take this “processed” file and send it to my remote log server using syslog-ng.
Anyway, I thank you all in advance! :blush:
Have you been through the documentation covering the database schemas? Redirecting...
Yes, I’ve seen that, but I don’t understand how to make the client (IP) get the resolved hostname.
table client
I even explored the database and viewed the tables, but I couldn’t create a query that brings the information as it is shown in the "Query log" menu.
The data in the Query Log page is retrieved via API call to pihole-FTL.
The API call returns data from the last 24h, from an in-memory database (you can't access this data directly).
On the other hand, the data stored into the database is shown in the web interface when you access the Long-term Data > Query Log.
Note:
All queries are stored into the database using only the IP (not hostname).
The hostnames (when available) are stored in a different table client_by_id, but not every IP has a hostname and some IPs have more than one hostname.
The web interface uses this SQL code to return the Long-term Data > Query Log data:
You can adapt the code for your needs.
I'd recommend to stick with the IP, or use hostnames only as additional information.
The DNS protocol exclusively uses IPs to identify a requestor. Pi-hole puts in additional effort to associate IPs with a name to display in its dashboard, but that information is derived - it isn't available from the original DNS request (which is why it isn't present in the logged DNS requests).
If you use hostnames only instead, you'll lose information.
A device with a name may have multiple network interfaces, and each network interface may carry multiple IPv4 and IPv6 addresses, and especially IPv6 addresses can be expected to change over time.
