[Help] [Question] Pihole ssl comodo
I bought an ssl certificate and it came to me with 3 files in one rar.
AAACertificateServices.crt
HSSL.key
mydomain.com.crt
How can I install this ssl certificate in pihole?
I was able to do it in apache2 but I don't understand how it's done in pihole.
apache2
<VirtualHost *:443>
ServerName mydomain.com
<Directory /var/www/html>
allow from all
Options None
Require all granted
SSLEngine on
SSLProtocol +TLSv1 +TLSv1.1 +TLSv1.2
SSLCertificateFile /etc/apache2/ssl/mydomain.com.crt
SSLCertificateKeyFile /etc/apache2/ssl/HSSL.key
SSLCACertificateFile /etc/apache2/ssl/AAACertificateServices.crt
SSLVerifyClient none
DocumentRoot /var/www/html
I saw this video but I don't understand it, I see that it creates certificates and then puts only 2 files in lighttpd.
I have 3 files and they are not .pem extension.
I have ubuntu 16.04.7 LTS x86_64
Thank you very much.
I don't know if this is the correct area to do this query, excuse my ignorance.
I do not speak english, I am using a translator.
Following this tutorial:
I have these files:
HSSL-etc.key
midominio.com.crt
SectigoRSADomainValidationSecureServerCA.crt
USERTrustRSAAAACA.crt
In the tutorial I see that it places 3 files:
/etc/letsencrypt/live/pihole.example.com/privkey.pem /etc/letsencrypt/live/pihole.example.com/cert.pem /etc/letsencrypt/live/pihole.example.com/combined.pem
privkey.pem would be HSSL-etc.key
cert.pem would be midominio.com.crt
combined.pem would be AAACertificateServices.crt
Or I'm wrong?
So, just change the extension.
Following this: ssl - How to get .pem file from .key and .crt files? - Stack Overflow
/etc/letsencrypt/live/pihole.example.com/HSSL-etc.pem
/etc/letsencrypt/live/pihole.example.com/midominio.com.pem
/etc/letsencrypt/live/pihole.example.com/AAACertificateServices.pem
So I see it edit: /etc/lighttpd/external.conf
$HTTP["host"] == "pihole.example.com" {
Ensure the Pi-hole Block Page knows that this is not a blocked domain
setenv.add-environment = ("fqdn" => "true")
Enable the SSL engine with a LE cert, only for this specific host
$SERVER["socket"] == ":443" {
ssl.engine = "enable"
ssl.pemfile = "/etc/letsencrypt/live/pihole.example.com/combined.pem"
ssl.ca-file = "/etc/letsencrypt/live/pihole.example.com/fullchain.pem"
ssl.honor-cipher-order = "enable"
ssl.cipher-list = "EECDH+AESGCM:EDH+AESGCM:AES256+EECDH:AES256+EDH"
ssl.use-sslv2 = "disable"
ssl.use-sslv3 = "disable"
Redirect HTTP to HTTPS
$HTTP["scheme"] == "http" {
$HTTP["host"] =~ ".*" {
url.redirect = (".*" => "https://%0$0")
So what I understand is this:
ssl.pemfile = "/etc/letsencrypt/live/pihole.example.com/AAACertificateServices.pem"
Then it changed:
And this file? fullchain.pem
Then I change all pihole.example.com to my domain example.com
Then:
sudo service lighttpd restart
And it does not work.
What am I doing wrong?
I think my problem is in the file: combined.pem
I see there are 3 types of combined.pem
Which would be correct?
And what would this file be?
fullchain.pem
It never uploads it to that folder.
I went to sectigo.com and I saw this:
-----BEGIN RSA PRIVATE KEY-----
(Your Private Key: your_domain_name.key)
-----END RSA PRIVATE KEY-----
-----BEGIN CERTIFICATE-----
(Your Primary SSL certificate: your_domain_name.crt)
-----END CERTIFICATE-----
(Your Intermediate certificate: SectigoRSA.crt)
(Your Root certificate: USERTrustRSACertificationAuthorityCARoot.crt)
Then it would be like this:
HSSL.key
domain.com.crt
I am right?
This would be the combined.pem file that I see in this tutorial:
If I'm wrong, correct me.
Thanks, I think I'm making progress.
#sudo service lighttpd restart
#sudo service lighttpd status
● lighttpd.service - Lighttpd Daemon
Loaded: loaded (/lib/systemd/system/lighttpd.service; enabled; vendor preset: enabled)
Active: failed (Result: exit-code) since vie 2020-09-18 18:22:33 -03; 8s ago
Process: 83344 ExecStart=/usr/sbin/lighttpd -D -f /etc/lighttpd/lighttpd.conf (code=exited, status=255)
Process: 83333 ExecStartPre=/usr/sbin/lighttpd -t -f /etc/lighttpd/lighttpd.conf (code=exited, status=0/SUCCESS)
Main PID: 83344 (code=exited, status=255)
sep 18 18:22:33 ubuntu systemd[1]: Starting Lighttpd Daemon...
sep 18 18:22:33 ubuntu lighttpd[83333]: Syntax OK
sep 18 18:22:33 ubuntu systemd[1]: Started Lighttpd Daemon.
sep 18 18:22:33 ubuntu lighttpd[83344]: 2020-09-18 18:22:33: (network.c.734) SSL: error:02001002:system library:fopen:No such file or directory /etc/letsencrypt/live/example.com/fullchain.pem
sep 18 18:22:33 ubuntu lighttpd[83344]: 2020-09-18 18:22:33: (network.c.870) SSL: error:20074002:BIO routines:FILE_CTRL:system lib /etc/letsencrypt/live/example.com/fullchain.pem
sep 18 18:22:33 ubuntu systemd[1]: lighttpd.service: Main process exited, code=exited, status=255/n/a
sep 18 18:22:33 ubuntu systemd[1]: lighttpd.service: Unit entered failed state.
sep 18 18:22:33 ubuntu systemd[1]: lighttpd.service: Failed with result 'exit-code'.
Apparently the bug is in fullchain.pem
What would this .pem look like?
I made it.
I leave the solution in case someone needs it:
1 .key
2 domain.com.crt
3 SectigoRSADomainValidationSecureServerCA.crt
4 USERTrustRSAAAACA.crt
Open the 4 files and paste the 4 texts in a single file and place it as a .pem extension
Then we change the extension to the AAACertificateServices.crt file for .pem
This would be the fullchain.pem
We already have the two .pem files
We create the folder /etc/letsencrypt/live/pihole.example.com/
pihole.example.com would be the name of our domain.
With permissions rw-r--r-- (0644)
We copy the .pem files that we create in this folder.
sudo chown www-data -R /etc/letsencrypt/live
We open /etc/lighttpd/external.conf
If I did something wrong, they correct me, thank you.
