Hi everyone,
I need help configuring Pi-hole to continue acting as a local DNS server without enabling its DHCP server.
In my setup:
- I'm using Kea DHCP as my DHCP server.
- My local domain is properly defined in Kea (e.g.,
home.local). - Pi-hole has a static IP address that is within the IP range managed by Kea.
- I want Pi-hole to correctly resolve local hostnames (provided via Kea) and still function as the main DNS server for all clients on the network.
What’s the best way to make Pi-hole aware of the hostnames and IPs provided by Kea, without using Pi-hole’s built-in DHCP?
Any advice on how to set this up correctly is much appreciated!
Thanks in advance!
