Help by setting Unbound + Pihole on Portainer.
Expected Behaviour
I want to run Pi-hole with Unbound (recursive, no external upstreams) using Docker and Portainer and I’m unsure about the recommended architecture.
I already have Pi-hole running successfully in its own Docker container, and now want to add Unbound in the correct way.
Specifically, I’m confused about:
  • running Pi-hole and Unbound as two separate containers vs one combined container
  • using individual containers vs a Docker stack (docker-compose) in Portainer
My goal is a clean, maintainable, best-practice setup without unnecessary complexity.
System Details
  • OS: Debian (Raspberry Pi OS)
  • Hardware: Raspberry Pi (8GB)
  • Docker: Docker standalone (Portainer, not Swarm)
Actual Behaviour
Pi-hole works fine as a container, but when adding Unbound I find conflicting advice:
  • some guides use two containers
  • some combine everything into one container
  • some insist on docker-compose stacks
Portainer handles stacks and containers differently, which adds to the confusion.
Main Question
What is the recommended and supported way today to run Pi-hole + Unbound with Docker?
  • Separate containers or one container?
  • Stack or individual containers?
  • Is there any tutorial?
There is no right or wrong answer for these questions.
    Pi-hole only has official images for Pi-hole. No images containing Unbound.
    If you want to use a single image for both servers, then you will need to use a third party image.
    This is a personal choice. Use what feels comfortable.
    You can use:
    • docker run command, on the command line.
    • docker compose command, on the command line.
    • use a single Portainer "stack" (a compose file containing both services) or
    • use 2 separate Portainer "stacks"
    Since this is an user's choice, each user has a personal way to do it.
    Suggestion: check the example from this answer: Best way to add unbound to existing Docker pihole? - #2 by rdwebdesign
