GUI not allowing access
go to http://192.168.2.254/admin
be welcomed with the password screen
Page shows timeout
yvb7axero3
I have tried every solution i could find on the forums from lighthttpd stop/start/restart, check the log permissions and erros
Adicional information: going to the same page on mobile/android i get the
[Failed CORS: null vs 192.168.2.254 erro but not on the PC
Please post the token generated by
Tools > Generate Debug Log
I'm sorry but i have genereated and shared the token:yvb7axero3
However here is a new generated just now: a1n025ntek
My pi-hole is running only the gui isn't accessible.
Thank you for your time
Keep an eye on Referrer-Policy header which must not be set to "no-referrer" for CORS to function. HTTP_ORIGIN = null is/can be a result of no-referrer policy.
But the Pi-hole lighttpd.conf overwrites any server-wide/parent response headers, hence when you chose to install Lighttpd via Pi-hole installer, the reason seems to be a different one.
