GUI/Function Enhancement - Remote DNS Syslog Forwarding
Thank you for the great work with pi-hole!
I would like to request an enhancement, allowing for DNS call logging to a remote logger, via the gui. The intent would be to have long term (historic) archiving of all DNS calls (with check boxes for the to enable/disable log types). With this feature, it will allow for the query of dns names and/or ip's, for correlation purpose (via my SIEM solution).
In a corporate environment, if there is a defined logging setup option, for compliance/audit purpose, there will potentially be a higher adoption rate from that perspective (auditors want screenshots of where in the gui the logger is setup).
Thank you in advance.
Closed as duplicate.
Votes and discussion was transfered.
