Group management not working as expected on standard pihole setup
  1. Installed pihole as per the One-Step Automated Install.
  2. Updated the DNS of my Linksys Router (Model SPNMX42) to point to the IP of my raspberrypi device.
  3. Created a resevred IP for my raspberrypi device.
  4. No other customisations made.
Following Example 1: Exclude from blocking, I would expect my device to be completely unblocked.
Client blocks ads.
https://tricorder.pi-hole.net/IqNUHCCD/
to nie jest odosobniony przypadek . Zjadłem zęby na tym i NIC. Próbowałem wszystkiego a on i tak traktuje wszystkich w sieci jednakowo.
Did you manage to fix it?
You group assignment seems to be fine:
  • your created some groups. The last one is Laptop, with ID=3;
  • you also configured a few devices. You configured your laptop to use group Laptop;
  • the Laptop group is not using any lists. This means any device in this group should not be blocked.
On the other hand, I noticed your router is advertising itself as DNS server:
      dns-server: 192.168.1.1
      router: 192.168.1.1
Apparently your router is the only device using Pi-hole.
In this configuration, your laptop will use the router as DNS server and the router will use Pi-hole.
Pi-hole will only see the router, which is using the Default group.
To make sure, what is the output of these 2 commands, running from your laptop command line?
nslookup flurry.com
nslookup flurry.com 192.168.1.138
Thanks for the response. You have summarised the issue accurately. My laptop is allowing requests, when it should not.
Here is the output you requested:
nslookup flurry.com
Server:  UnKnown
Address:  2a02:6b60:9b91:0:8269:1aff:fe10:4f81
*** UnKnown can't find flurry.com: No response from server
Server:  pi.hole
Address:  192.168.1.138
Non-authoritative answer:
Addresses:  76.223.84.192
          13.248.158.7
To add to this, I noticed the following message on the diagnostics page:
Client 192.168.1.1 has been rate-limited (current config allows up to 1000 queries in 60 seconds)
Indies this have anything to do with my issue?
These 2 sentences are contradicting each other.
What exactly do you want?
a) my laptop should be completely unblocked, allowing every query (and show ads)
b) my laptop should block ads
Sorry I realised my error in the earlier posts. I want my laptop to allow ads after adding it to the laptop group.
So do you know why I am experiencing this issue? The Laptop group does not have any associated adlists, so I would expect my laptop to display ads. However as I mentioned, it contributes to block ads.
