Maybe I'm using this wrong (but I don't think I am), but this new "feature" (what was wrong with how it handled lists before? absolutely nothing) is total crap.
So here is an example of some URLs that need to be added to PiHoles list.
https://raw.githubusercontent.com/hectorm/hmirror/master/data/disconnect.me-ad/list.txt
https://raw.githubusercontent.com/hectorm/hmirror/master/data/disconnect.me-malvertising/list.txt
https://raw.githubusercontent.com/hectorm/hmirror/master/data/disconnect.me-malware/list.txt
https://raw.githubusercontent.com/hectorm/hmirror/master/data/disconnect.me-tracking/list.txt
Now, I am FORCED to go into Group Management -> Adlists in order to add these to the list. Sure. Fine. Go there, based purely on the text in the type bar before you type anything (see here: https://i.imgur.com/fT1HPkE.png ) the formate that you want is link, link, link,. Guess what. That doesn't work.
Here is the exact format I copy pasted into the bar.
https://raw.githubusercontent.com/hectorm/hmirror/master/data/fademind-add.2o7net/list.txt, https://raw.githubusercontent.com/hectorm/hmirror/master/data/fademind-add.dead/list.txt, https://raw.githubusercontent.com/hectorm/hmirror/master/data/fademind-add.risk/list.txt, https://raw.githubusercontent.com/hectorm/hmirror/master/data/fademind-add.spam/list.txt
And here is the nice happy little error message I get: https://i.imgur.com/7cwkLFB.png
Ok. Maybe what you really ment was link , link , (notice the space inbetween the , ). Right? Surely thats it.
So lets try again with this format.
https://raw.githubusercontent.com/hectorm/hmirror/master/data/fademind-add.2o7net/list.txt ,
https://raw.githubusercontent.com/hectorm/hmirror/master/data/fademind-add.dead/list.txt ,
https://raw.githubusercontent.com/hectorm/hmirror/master/data/fademind-add.risk/list.txt ,
Lol nope. https://i.imgur.com/ko0oaF0.png
Now, you might be sitting there thinking "oh well clearly there is just something wrong with these links." LOL nope.
Lets try doing each link, one, by, one.
This one results in an error. Ok. Cool. Good for you. You found a bad link. https://i.imgur.com/iJH0tTy.png
So......does that mean ALL the links are bad? No....
The very next url in the list works just fine. Literally the Second URL. See here: https://i.imgur.com/6b5mT8P.png
But with the new Group Management Adlist "feature" it will just........stop.......at the first error. And not even TRY to do anything after that.
The previous method of adding Adlists worked flawlessly. You dump a huge list of URLs into it. It parses the list. Sometimes it finds errors, but it moves onto the next item in the list and continues until the entire list of URLs is done.
This new "feature" is 1 step forward 2 steps back. I am sitting here with a new list of Lists that has 102 URLs. I don't have time to sit here and copy paste 102 times while pressing "Add" each time. Thats unrealistic and quite frankly assenine.
Request return of previous superior "feature".
