Hallo zusammen,
der Job für die Aktualisierung der Blocklisten läuft standardmäig von Samstag auf Sonntag Nacht zwischen 3 und 5 Uhr morgens.
Wie kann ich den Job anpassen nach individuellen Wünschen?
Weiß das jemand ?
Hallo zusammen,
Weiß das jemand ?
pi@ph5a:~ $ cat /etc/cron.d/pihole
# Pi-hole: Update the ad sources once a week on Sunday at a random time in the
# early morning. Download any updates from the adlists
# Squash output to log, then splat the log to stdout on error to allow for
# standard crontab job error handling.
6 4 * * 7 root PATH="$PATH:/usr/sbin:/usr/local/bin/" pihole updateGravity >/var/log/pihole/pihole_updateGravity.log || cat /var/log/pihole/pihole_updateGravity.log
pi@ph5a:~ $ man cron
NAME
cron - daemon to execute scheduled commands (Vixie Cron)
Additionally, in Debian, cron reads the files in the
/etc/cron.d directory. cron treats the files in
/etc/cron.d as in the same way as the /etc/crontab file
(they follow the special format of that file, i.e. they
include the user field).
SEE ALSO
crontab(1), crontab(5), run-parts(8)
pi@ph5a:~ $ man 5 crontab
The format of a cron command is very much the V7 standard,
with a number of upward-compatible extensions. Each line
has five time and date fields, followed by a command, fol‐
lowed by a newline character ('\n'). The system crontab
(/etc/crontab) uses the same format, except that the user‐
name for the command is specified after the time and date
fields and before the command. The fields may be sepa‐
rated by spaces or tabs. The maximum permitted length for
the command field is 998 characters.
Commands are executed by cron(8) when the minute, hour,
and month of year fields match the current time, and when
at least one of the two day fields (day of month, or day
of week) match the current time (see ``Note'' below).
cron(8) examines cron entries once every minute. The time
and date fields are:
field allowed values
minute 0–59
hour 0–23
day of month 1–31
month 1–12 (or names, see below)
day of week 0–7 (0 or 7 is Sun, or use names)
A field may be an asterisk (*), which always stands for
``first-last''.
Danke, aber ich erkenne jetzt nicht wie ich es anpassen kann.
Wie und was muss ich editieren damit der Job täglich um 5 Uhr morgens läuft?
Mine is scheduled at 4:42 hours every Sunday (7):
pi@ph5a:~ $ grep updateGravity /etc/cron.d/pihole
42 4 * * 7 root PATH="$PATH:/usr/sbin:/usr/local/bin/" pihole updateGravity >/var/log/pihole/pihole_updateGravity.log || cat /var/log/pihole/pihole_updateGravity.log
To change to 5:00 hour:
pi@ph5a:~ $ sudo sed -i '/updateGravity/ s/^.*root/0 5 * * 7 root/' /etc/cron.d/pihole
pi@ph5a:~ $
Check:
0 5 * * 7 root PATH="$PATH:/usr/sbin:/usr/local/bin/" pihole updateGravity >/var/log/pihole/pihole_updateGravity.log || cat /var/log/pihole/pihole_updateGravity.log
EDIT: I changed the sed command a bit bc of the weird spacing!
Danke, also wenn ich das täglich um 5 Uhr machen möchte.. .ist das dann richtig?
sudo sed -i '/updateGravity/ s/^.*root/0 5 * * * root/' /etc/cron.d/pihole
Spot on.
But why?
Weekly is the recommended default.
Oh sorry, the asterixes "*" should be escaped with a backslash "\" bc of special meaning.
So it becomes:
sudo sed -i '/updateGravity/ s/^.*root/0 5 \* \* \* root/' /etc/cron.d/pihole
Ah bullocks, I believe above only applies for the matching criteria.
So below will do fine:
Ok, Änderung:
Check:
Result:
0 5 * * * root PATH="$PATH:/usr/sbin:/usr/local/bin/" pihole updateGravity >/var/log/pihole/pihole_updateGravity.log || cat /var/log/pihole/pihole_updateGravity.log
Ok there is a difference between posting below:
0 5 * * * root
Vs:
0 5 * * * root
Messing with the spaces in my sed
This is correct one:
EDIT: But why?
Thanks!
I just want a daily gravity update
Das ist ein ganz normaler Cron-Job, der mit den üblichen Tools geändert werden kann. deHakkelaar hat Dich diesbezüglich ja bereits mit den passenden Infos versorgt.
Noch ein Hinweis zum Update-Intervall:
Viele Blocklisten werden nicht täglich aktualisiert, zudem ist die Update-Frequenz individuell pro Blockliste stark unterschiedlich, von bedarfsweise über einmal pro Woche bis einmal pro Monat oder seltener.
Zudem werden Blocklisten häufig von Personen zusammengestellt und angeboten, die nur über begrenzte Online-Ressourcen verfügen.
Wenn deren Limit erschöpft ist, kann es sein, dass die Blocklist-Inhalte nicht mehr abrufbar sind, schlimmstenfalls für alle Nutzer.
Wenn Du nun bei Dir die Abruf-Frequenz auf einmal täglich anpasst, erhöhst Du potentiell den Verbrauch des Blocklisten-Betreibers, und das möglicherweise ohne zusätzlichen Nutzen.
Es würde also von der jeweiligen Auswahl von Blocklisten abhängen, ob eine Anpassung sinnvoll sein kann.
danke für deine Ausführungen. Vor diesem Hintergrund überlege ich, das Update nur alle 2 - 3 Tage zu machen.
Kannst du mir sagen, wie genau der Befehl dann heißen müsste?
I have to look this one up
