Gravity blocks too many things since v5 update
Pi-hole shouldn't block super common things like 'google.com'
pi-hole blocked google.com because gravity and I had to white list it. I find that since the v5 update, I have added more whitelisted domains than I did in the past year with previous versions leading up to v5.
https://tricorder.pi-hole.net/okimbf6u7m
Seems like you have a lot of adlists that are not well maintained and include a lot of false positives (like Google). Solution is to get rid of shitty adlists.
That doesn't really make sense; 'shitty' adlists that aren't maintained would have been throwing positives/blocks of common things before the upgrade to v5 wouldn't they?
But sure, I'm game to refine my lists and get more up to date stuff. Any particularly bad offenders you see in the lists I'm using? Can you recommend any that would be considered 'good/current/maintained'?
I don't have access to your token/list. It was more a general recommendation.
A lot of users use lists from: https://firebog.net/
If you include only lists, that are "Lists in green and bulleted with a tick are least likely to interfere with browsing", you should be relative save.
No. Prior to V5, the entire list was rejected. Starting in V5 we parse as much as possible and show how many domains were rejected in the output of pihole -g. You are likely using adblock or easy list formatted lists - these cause exactly this problem. Eliminate those lists and rebuild gravity.
Pi-hole doesn't block or allow anything on it's own. It blocks what you ask it to block via adlists. If you use adlists that include common domains like google.com on it, well, it will do what you ask and block google.com.
As the others have noted, don't use lists that include google.com as a domain to block.
I had used the easylist/adblock quite a while ago, but pulled it out because that one has been unsupported for pi-hole for quite a long time.
Here's my current gravity update output. There are definitely a couple that can come out for failing to find a list, but overall seems like a pretty normal refresh of gravity. The 'DNS service is not running' message irks me but I have a different help post open for that. A number of these are legitimately older lists and I am not sure when they were last maintained, see earlier post about updating some of them. Time to purge everything and start from scratch, I guess. Woo (/sarcasm)
  [i] Received 57718 domains
  [i] Target: https://mirror1.malwaredomains.com/files/justdomains
  [✓] Status: No changes detected
  [i] Received 26853 domains
  [i] Target: http://sysctl.org/cameleon/hosts
  [i] Received 20567 domains
  [i] Target: https://zeustracker.abuse.ch/blocklist.php?download=domainblocklist
  [i] Received 0 domains
  [i] Target: https://s3.amazonaws.com/lists.disconnect.me/simple_tracking.txt
  [i] Received 34 domains
  [i] Target: https://s3.amazonaws.com/lists.disconnect.me/simple_ad.txt
  [i] Received 2701 domains
  [i] Target: https://hosts-file.net/ad_servers.txt
  [✗] Status: Not found
  [✗] List download failed: no cached list available
  [i] Target: https://dbl.oisd.nl/
  [i] Received 1250033 domains
  [i] Target: https://phishing.army/download/phishing_army_blocklist_extended.txt
  [i] Received 16263 domains
  [i] Target: https://raw.githubusercontent.com/CHEF-KOCH/Audio-fingerprint-pages/master/AudioFp.txt
  [i] Received 371 domains
  [i] Target: https://raw.githubusercontent.com/CHEF-KOCH/Canvas-fingerprinting-pages/master/Canvas.txt
  [i] Received 14335 domains
  [i] Target: https://raw.githubusercontent.com/CHEF-KOCH/WebRTC-tracking/master/WebRTC.txt
  [i] Received 807 domains
  [i] Target: https://raw.githubusercontent.com/deathbybandaid/piholeparser/master/Subscribable-Lists/ParsedBlacklists/AakList.txt
  [i] Received 5 domains
  [i] Target: https://raw.githubusercontent.com/deathbybandaid/piholeparser/master/Subscribable-Lists/ParsedBlacklists/Prebake-Obtrusive.txt
  [i] Received 3 domains
  [i] Target: https://jasonhill.co.uk/pfsense/ytadblock.txt
  [✗] Status: https://jasonhill.co.uk/pfsense/ytadblock.txt (503)
  [✓] Storing downloaded domains in new gravity database
  [✓] Building tree
  [✓] Swapping databases
  [i] Number of gravity domains: 1389690 (1301580 unique domains)
  [i] Number of exact blacklisted domains: 1
  [i] Number of regex blacklist filters: 0
  [i] Number of exact whitelisted domains: 25
  [i] Number of regex whitelist filters: 0
  [✓] Cleaning up stray matter
  [✗] DNS service is NOT running
What does the following command show?
pihole -q google.com
I had whitelisted googleadservices because it broke a few things in android not to have it available, but that was well over a year ago, disabled it in the whitelist after pulling this output, fingers crossed it doesn't break things again.
root@lurker:~# pihole -q google.com
 Match found in exact whitelist
   adservice.google.com
  [i] Over 100 results found for google.com
        This can be overridden using the -all option
root@lurker:~# pihole -q -all google.com
 Match found in https://raw.githubusercontent.com/StevenBlack/hosts/master/hosts:
   adservice.google.com.vn
   fgoogle.com
   www.fgoogle.com
   marketingplatform.google.com
   smartlock.google.com
   ads.google.com
   ampcid.google.com
   fundingchoices.google.com
   pagead.l.google.com
   pagead-googlehosted.l.google.com
   pagead-tpc.l.google.com
   partnerad.l.google.com
   s0-2mdn-net.l.google.com
   www-googletagmanager.l.google.com
   video-stats.video.google.com
   adservice.google.com.tr
   www.doubleclickbygoogle.com
   adservice.google.com.au
   adservices.google.com
   ssl-google-analytics.l.google.com
   drive.google.com.it-barcelona.com
   adservice.google.com.mt
   analytics.google.com
   mail-ads.google.com
   www-google-analytics.l.google.com
 Match found in https://mirror1.malwaredomains.com/files/justdomains:
   ad.words-google.com
   www.google.com-document-view.alibabatradegroup.com
   email-google.com
 Match found in http://sysctl.org/cameleon/hosts:
   adwords.google.com
   agoogle.com
 Match found in https://s3.amazonaws.com/lists.disconnect.me/simple_ad.txt:
   pagead.l.google.com
 Match found in https://dbl.oisd.nl/:
   0-google.com
   6google.com
   a-dns-google.com
   abrial-jeremy.frgoogle.com
   account-google.com
   account.google.com.br-suporte.co
   account.google.com.ios-id.live
   account.google.com.suporte-br.cc
   accounts.google.com.anaisdormoy.com
   accounts.google.com.hash.uiushyyrttwggy7843jsnkk992mmdmm0995788nksk8uiieuuw.zatzeen.xyz
   accounts.google.com.nevareht.com
   accountsecurity-google.com
   acounts-google.com
   ads.google.com.cn
   ads.spreadsheets.google.com
   adservice.google.com.af
   adservice.google.com.ag
   adservice.google.com.ai
   adservice.google.com.ar
   adservice.google.com.bd
   adservice.google.com.bh
   adservice.google.com.bn
   adservice.google.com.bo
   adservice.google.com.br
   adservice.google.com.br.domain.name
   adservice.google.com.bz
   adservice.google.com.co
   adservice.google.com.cu
   adservice.google.com.cy
   adservice.google.com.do
   adservice.google.com.ec
   adservice.google.com.eg
   adservice.google.com.et
   adservice.google.com.fj
   adservice.google.com.gh
   adservice.google.com.gi
   adservice.google.com.gt
   adservice.google.com.hk
   adservice.google.com.jm
   adservice.google.com.kh
   adservice.google.com.kw
   adservice.google.com.lb
   adservice.google.com.ly
   adservice.google.com.mm
   adservice.google.com.mx
   adservice.google.com.my
   adservice.google.com.na
   adservice.google.com.nf
   adservice.google.com.ng
   adservice.google.com.ni
   adservice.google.com.np
   adservice.google.com.om
   adservice.google.com.pa
   adservice.google.com.pe
   adservice.google.com.pg
   adservice.google.com.ph
   adservice.google.com.pk
   adservice.google.com.pr
   adservice.google.com.py
   adservice.google.com.qa
   adservice.google.com.sa
   adservice.google.com.sb
   adservice.google.com.sg
   adservice.google.com.sl
   adservice.google.com.sv
   adservice.google.com.tj
   adservice.google.com.tw
   adservice.google.com.ua
   adservice.google.com.ua.domain.name
   adservice.google.com.uy
   adservice.google.com.vc
   advgoogle.com
   adwords.google.com
   agoogle.com
   ajax-google.com
   alert-google.com
   alerts-google.com
   alt1.aspmx.l.google.com.ntvk1.ru
   alt1.aspmx.l.google.com.xn.pl
   alt2.aspmx.l.google.com.ntvk1.ru
   alt2.aspmx.l.google.com.xn.pl
   alt3.aspmx.l.google.com.ntvk1.ru
   alt4.aspmx.l.google.com.ntvk1.ru
   analytic-google.com
   analytics-google.com
   analytics.corp.google.com
   android-google.com
   apis.google.com.signinv2.ru
   aspmx.l.google.com.adengage.com
   browserchannel-docs.l.google.comcdn.yldbt.com
   captive.adservice.google.com
   captive.adservice.google.com.br
   captive.adservice.google.com.mx
   captive.adservice.google.com.ng
   captive.adservice.google.com.ph
   captive.adservice.google.com.vn
   cert-test.sandbox.google.com
   chu-nice.frgoogle.com
   clients4-google.com
   clients6.google.com1873234.fls.doubleclick.net
   clients6.google.comads.creative-serving.com
   clients6.google.comi1-j1-18-23-1-18573-710414944-s.init.cedexis-radar.net
   com-google.com
   contact-google.com
   device-connection.customergoogle.com
   dl-google.com
   doodlegoogle.com
   downloads-google.com
   drive.google.com.arablatrade.com
   drive.google.com.pdfdocument.bcuworks.com
   drive.google.com.verify.signin.normandeassociation.com
   en-gb.google.com.signinv2.ru
   experto-google.com
   fcmatch.google.com
   fgoogle.com
   free.frgoogle.com
   frgoogle.com
   fundingchoicesmessages.google.com
   fusion.google.com
   ga-google.com
   google.com--vir.us
   google.com.1.302br.net
   google.com.certified-toolbar.com
   google.com.d-dns.co
   google.com.domainlogin.dovecs.com
   google.com.khanimambatraining.co.za
   google.com.super-fast-search.apsua.com
   google.comin.getclicky.com
   google.comsecure.adultfriendfinder.com
   google.comwad.ojooo.com
   google.frgoogle.com
   googleapis.l.google.compool1.moatads.com
   gstatic-google.com
   id.google.com.af
   id.google.com.ag
   id.google.com.ai
   id.google.com.ar
   id.google.com.bd
   id.google.com.bh
   id.google.com.bn
   id.google.com.bo
   id.google.com.br
   id.google.com.bz
   id.google.com.co
   id.google.com.cu
   id.google.com.cy
   id.google.com.do
   id.google.com.ec
   id.google.com.eg
   id.google.com.et
   id.google.com.fj
   id.google.com.gh
   id.google.com.gi
   id.google.com.gt
   id.google.com.hk
   id.google.com.iq
   id.google.com.jm
   id.google.com.kh
   id.google.com.kw
   id.google.com.lb
   id.google.com.ly
   id.google.com.mm
   id.google.com.mt
   id.google.com.mx
   id.google.com.my
   id.google.com.na
   id.google.com.nf
   id.google.com.ng
   id.google.com.ni
   id.google.com.np
   id.google.com.om
   id.google.com.pa
   id.google.com.pe
   id.google.com.pg
   id.google.com.ph
   id.google.com.pk
   id.google.com.pr
   id.google.com.py
   id.google.com.qa
   id.google.com.sa
   id.google.com.sb
   id.google.com.sg
   id.google.com.sl
   id.google.com.sv
   id.google.com.tj
   id.google.com.tr
   id.google.com.tw
   id.google.com.ua
   id.google.com.uy
   id.google.com.vc
   id.google.com.vn
   id.google.comin.getclicky.com
   id.l.google.com
   imagse-google.com
   imges-google.com
   incoming.telemetry.mozilla.orgkh.google.comlax1-ib.adnxs.com
   intra.notaires.frgoogle.com
   link-google.com
   mail-ads.google.com
   mail.google.commatch.basebanner.com
   mail.upgoogle.com
   mailorange.frgoogle.com
   mails-google.com
   mange.google.com.brunocpa.com
   microsoft-google.com
   mmogoogle.com
   mogoogle.com
   msn-google.com
   mx20.google.com.usadserver.com
   myacccounts-google.com
   myaccounts-google.com
   myactivity-google.com
   news-server-drm-google.com
   noreply-google.com
   numbers-google.com
   okay-google.com
   optimize.google.com
   pagead-googlehosted.l.google.comv4.moatads.com
   pagead.l.google.com
   passwordgoogle.com
   play.l.google.comi1-j1-18-23-1-18573-3782033469-s.init.cedexis-radar.net
   plus.google.compm-m.d.chango.com
   query-google.com
   raigoogle.com
   s1.dugoogle.com
   sb-ssl.l.google.compool1.moatads.com
   sb.l.google.com2895566.fls.doubleclick.net
   schellman-google.com
   schuff-google.com
   settings-google.com
   static-2mdn-net.l.google.com
   static-doubleclick-net.l.google.com
   static-google.com
   stats-google.com
   stats10-google.com
   supportbygoogle.com
   survey-google.com
   tokenized.play.en-gb.google.com.signinv2.ru
   tomsgoogle.com
   toolbar.google.com
   translate.translategoogle.com
   translategoogle.com
   translatorgoogle.com
   union-google.com
   update.google.com.updatesrvers.org
   uulive-google.com
   verify-google.com
   video-analytics.l.google.com
   ww.translategoogle.com
   ww1.analytic-google.com
   ww1.frgoogle.com
   ww1.passwordgoogle.com
   ww1.raigoogle.com
   ww1.translategoogle.com
   ww1.translatorgoogle.com
   ww1.wwwogoogle.com
   ww10.translategoogle.com
   ww25.frgoogle.com
   ww38.raigoogle.com
   ww43.analytic-google.com
   www-google-analytics.l.google.comnym1-ib.adnxs.com
   www.0-google.com
   www.6google.com
   www.account-google.com
   www.accountsecurity-google.com
   www.acounts-google.com
   www.advgoogle.com
   www.agoogle.com
   www.ajax-google.com
   www.alerts-google.com
   www.analytic-google.com
   www.analytics-google.com
   www.android-google.com
   www.clients4-google.com
   www.com-google.com
   www.contact-google.com
   www.dl-google.com
   www.doodlegoogle.com
   www.downloads-google.com
   www.experto-google.com
   www.fgoogle.com
   www.frgoogle.com
   www.ga-google.com
   www.google.com.d-dns.co
   www.gstatic-google.com
   www.imagse-google.com
   www.imges-google.com
   www.link-google.com
   www.mails-google.com
   www.microsoft-google.com
   www.mmogoogle.com
   www.mogoogle.com
   www.myacccounts-google.com
   www.myaccounts-google.com
   www.myactivity-google.com
   www.noreply-google.com
   www.okay-google.com
   www.passwordgoogle.com
   www.query-google.com
   www.raigoogle.com
   www.schellman-google.com
   www.schuff-google.com
   www.settings-google.com
   www.static-google.com
   www.stats-google.com
   www.stats10-google.com
   www.supportbygoogle.com
   www.survey-google.com
   www.tomsgoogle.com
   www.translategoogle.com
   www.translatorgoogle.com
   www.union-google.com
   www.uulive-google.com
   www.verify-google.com
   www.www5-google.com
   www.wwwogoogle.com
   www.yogoogle.com
   www.youtube-google.com
   www3.l.google.compixel.everesttech.net
   www5-google.com
   wwwogoogle.com
   xnsx.translategoogle.com
   yogoogle.com
   youtube-google.com
   ytstatic.l.google.com
   z-google.com
 Match found in https://phishing.army/download/phishing_army_blocklist_extended.txt:
 Match found in https://raw.githubusercontent.com/CHEF-KOCH/Canvas-fingerprinting-pages/master/Canvas.txt:
   9to5google.com
I should have provided a more suitable command to filter out all the noise (on mobile today). Apologies.
pihole -q -exact google.com
When it came back with no matches, I was confused because I know I had explicitly whitelisted google.com, and it wasn't showing in my UI. Slipped my mind that I actually have two pi-hole installations; one is for my house (which I've been generating output from so far), the other is on a vpn server I created for our wireless devices when we leave the house (using a hosted virtual server because our ISP doesn't allow incoming connections). It appears that I removed the adblock/easylist entries from the house one but not from the vpn pi-hole, so I can clean that up easy enough. The general tendency to need to add a lot more domains to the whitelist than I ever had with non v5 versions of pi-hole is still of concern though. I think I'll wipe both of these pi-hole installs clean on lists and make sure they both match.
To that end, is there a way to export the collection of lists (whitelist, blacklist, gravity lists) from my home instance and import them into the VPN server instance or will I need to do it all by hand?
root@localhost:~# pihole -q -exact google.com
 Exact match found in exact whitelist
   google.com
 Exact matches for google.com found in:
  - Https://easylist-downloads.adblockplus.org/easylist.txt
  - https://easylist-downloads.adblockplus.org/easylist.txt
Use the Pi-hole teleporter function.
Perfect, thanks!
