Google Drive not working
Hi, ever since the last update, or the last couple, not sure, i cant get google drive to work. if whitelisted the recommended google sites and some other, but still nothing. Google Drive works when disable pihole.
logs token: 7f191yjlrv
thanks!
Hmm I see the same thing. I can load up my docs, but other tabs like Shared with me or Recent, just spin until you get the Server encountered an error message. However, none of the queried domains seem to be blocked.
Will have to look into this one.
Thanks. it's very strange. The query log does not show any blocked domains when. It working.
Google drive seems to be working for me.
Shared with me & Recent are all working fine here
Wonder if it is region specific? I'm in the UK
Can confirm, no issues here, either.
Very strange indeed. it doesnt work with pihole enabled, it works with pihole disabled.
Will you please try whitelisting clients6.google.com, waiting for more than 300 seconds, and then refresh the page and try again?
pihole -w clients6.google.com
i was about to -w clients6.google.com like you suggested in your last post but it already had been white listed days ago when i first encountered the problem and continued to have problems. tried it without doing anything different today, and it works!
you know this is very strange. when i first posted the problem, as you saw in post #2, no google doc or drive domains were being blocked or shown as according to the query log and it did not work.
Now that it works, i see domains like 0.docs.google.com being ok.
very strange, but its working now.
OK, unless we hear otherwise, let's say
pihole -w clients6.google.com 0.docs.google.com
seems to solve the issue.
Your browser may have also done some local caching.
I was having an issue, even after
it seemed to be resolved after adding
pihole -w csi.gstatic.com
Not sure if this will have any further effects yet
i have solved it with adding this domain: "accounts.google.com" to my whitelist
