Google Ads and As Double-click not being blocked
*Google Ads and ad double clixk not being blocked
Any app or website using the above services will not display an ad
Ads being displayed on web page
https://tricorder.pi-hole.net/O8C7q5eI/
I've updated this so please review the debug token
The debug log shows that your router's DHCP server is giving out its own IP (the router) to clients to use for DNS.
     Server IP address: 192.168.1.254
      dns-server: 192.168.1.254
      router: 192.168.1.254
It needs to be giving out the Pi-hole's IP 192.168.1.94 instead. Update the router's DHCP settings so it's only giving out the Pi-hole's IP address as DNS. Then bounce the clients off and back on to the network to pick up the new settings.
The debug log also shows that Pi-hole is working to block domains when it is being used.
