Going up and down randomly
I always get told to use the template, but switching to help docker removes the template
pi-hole is going up and down, DHCP and DNS stops completely, and DHCP leases end
I did a debug log and it looked like it had errors, so here it is
Your debug token is: https://tricorder.pi-hole.net/xStgSgxs/
I have this issue before, didn't I
High Load on the host seems to cause the FTL crash
For docker help we usually request 2 things:
  • a debug log (just like you did);
  • the compose file or docker run command used to start the container.
Include that somewhere then, anyway I think the issue was just high load again
My host system seems to do this from time to time
