Github.com and github.tools.sap slow
I read all the posts about slow resolution. I did
  • dig and nslookup the urls in question, the answer time is always below 60ms
  • change the blocking mode both to NODATA and NXDOMAIN
  • ran pihole debug and got two warnings
  • ran without pihole (over my mobile hotspot and with pi-hole off) and it is definitely only there when the pi-hole is enabled
  • skipped some ipv6 "solutions" out there because I have ipv6 not enabled in my internal network
HTTP/1.1 200 OK
Expires: Thu, 11 Mar 2021 20:21:33 GMT
Cache-Control: max-age=0
Date: Thu, 11 Mar 2021 20:21:33 GMT
Server: lighttpd/1.4.53
and
   fe80::6201:75ad:e2df:4132 does not match the IP found in /etc/pihole/setupVars.conf (https://discourse.pi-hole.net/t/use-ipv6-ula-addresses-for-pi-hole/2127)
I expect ALL pages to be either slow or fast, not just
  • github.com
  • github.tools.sap
Note: I have to say that this only happens on my 11.2.2 Big Sur OSX (my phones seem to be always fast, same for the ipad) and I think only for Chrome (Version 88.0.4324.192 (Official Build) (x86_64)
). I do not know if the other browsers just did not cache something yet or if they generally behave differently
These two URLs are the only ones I can identify as slow, the rest of all pages out there run just fine.
https://tricorder.pi-hole.net/9stkytdh9l
Some facts
  • I have a https://www.asuswrt-merlin.net/ firmware on my router.
  • ipv6 routing is completely disabled (not sure if smart but just felt like it back then).
  • I have a gut feeling it could be related to GH (and GHES) using ipv6 or so
  • DNS over HTTPS in Chrome is OFF
I am seriously at the end of my ideas and research. Thank you to anyone that has a good idea.
Only one browser on one machine and two domains affected are very strong indications that Pi-hole isn't involved here, especially since your debug log shows you are not using group management to filter only specific clients.
I've switched your topic to the Community Help category accordingly.
If it is indeed only Chrome exhibiting this behaviour, you may want to check that DoH is disabled, and its "use a web service to help resolve navigation errors" (or similar) option should be disabled as well.
DoH is disabled but the other setting you state I can not find where it should be in my Chrome Version.
I forgot to mention one thing in the original post: When I restart the DNSResolver, for a very very short time, the pages are fast! :face_with_monocle:
at:Bucking_Horn I agree that it is weird. But why does my same (100%) laptop work then directly after pihole is disabled or when I use my mobile hotspot? :frowning_face:
That's a common privacy feature for all Chromium based browsers, though it may be named differently across browsers and versions, e.g. Chromium Edge matches the qouted string, Vivaldi shortens it to "DNS to help resolve navigation errors" under a Google Services section.
That feature may try to resolve a blocked domain name via Google's DNS servers after the browser has received 0.0.0.0 from Pi-hole, slowing down resolution and by-passing Pi-hole at the same time.
Try to search for DNS options in your browser's settings, or do a web research for your specific browser.
Whether those options actually help to address your problem is just a guess.
However, it is generally sound to disable these options when using Pi-hole for DNS.
I can not find that setting in Chrome 88, it is just not there, DNS yields 1 result: DOH, and it's disabled.
I wanted to switch to Brave since long anway, here I come :rofl:
I now "lived" it for some hours and I just come to the conclusion that something is off.
I go to GH or GHES or also this page (discourse) and then it takes like 10s to load. But then, the next clicks all is fast, until I go idle again on that browser. If I come back, 10s wait.
It seems that some kind of cache or TTL expires.
Also, it happens in Brave too. I have a worm sitting somewhere.
This is a request from idle:
like 20s are spent on "waiting" for something grey :face_with_monocle:
Okay, I get on its tracks definitely its not DNS. It has to do with that Stalled.
I see it e.g. being stalled for 30s for https://api.github.com/_private/browser/stats before it times out.
Same for https://discourse.pi-hole.net
It seems to just being stalled, and I have yet no green twig why :slightly_frowning_face:
