Just to note, I typically run pihole -up
as a cronjob. This failed last night, and the details of my subsequent attempted updates are also listed below.
Running pihole -up
, get updated to the latest version
Initially, I got the following:
[i] Checking for updates...
[i] Pi-hole Core: update available
[i] FTL: update available
[i] Web Interface: update available
[i] Updating Pi-hole core and web admin files
[i] Check for existing repository in /etc/.pihole...
e[K [✓] Check for existing repository in /etc/.pihole
[i] Update repo in /etc/.pihole...
e[K [✓] Update repo in /etc/.pihole
[✓] Root user check
.ccccc:,.
:cccclll:. ..,,
:ccccclll. ;ooodc
'ccll:;ll .oooodc
.;cll.;;looo:.
[i] Existing PHP installation detected : PHP version 7.0.27-0+deb9u1
[i] Performing unattended setup, no whiptail dialogs will be displayed
[✓] Disk space check
[i] Update local cache of available packages...
e[K [✗] Update local cache of available packages
Error: Unable to update package cache. Please try "apt-get update"
I resolved this, by running apt update && apt full-upgrade -y
however, I'm now getting the following:
[i] Pi-hole Core: up to date
[i] FTL out of date
[i] FTL Checks...
[i] Downloading and Installing FTL...curl: (22) The requested URL returned error: 404 Not Found
Error: URL not found
After doing a bit of checking, I found that this appears to be because the update script (bash -x /opt/pihole/update.sh
) is trying to go to an invalid Github page:
Here's an exerpt from that script's output in -x mode
+ echo -e ' [i] FTL Checks...'
[i] FTL Checks...
+ FTLcheckUpdate
+ local FTLversion
++ /usr/bin/pihole-FTL tag
+ FTLversion=
+ local FTLlatesttag
++ curl -sI https://github.com/pi-hole/FTL/releases/latest
++ grep Location
++ awk -F / '{print $NF}'
++ tr -d '\r\n'
+ FTLlatesttag=v4.0
+ [[ '' != \v\4\.\0 ]]
+ return 0
+ FTLinstall ''
+ local binary=
+ local latesttag
+ local 'str=Downloading and Installing FTL'
+ echo -ne ' [i] Downloading and Installing FTL...'
[i] Downloading and Installing FTL...++ curl -sI https://github.com/pi-hole/FTL/releases/latest
++ grep Location
+ latesttag=$'v4.0\r'
== v* ]].0
++ mktemp -d
+ pushd /tmp/tmp.mOTgBJ0tTU
+ install -T -m 0755 /etc/.pihole/advanced/Templates/pihole-FTL.service /etc/init.d/pihole-FTL
+ local ftlBranch
+ local url
+ [[ -f /etc/pihole/ftlbranch ]]
+ ftlBranch=master
+ [[ master == \m\a\s\t\e\r ]]
+ url=https://github.com/pi-hole/FTL/releases/download/v4.0
+ curl -sSL --fail https://github.com/pi-hole/FTL/releases/download/v4.0/ -o ''
+ popd
+ echo -e '\r [✗] Downloading and Installing FTL'
+ echo -e ' Error: URL not found'
+ return 1
+ return 1
h5hqgcgw8j
