Function not supported in Docker images
Hello,
I've installed pihole 6 beta bare metal. When I execute the update function
$ pihole -up
I got the message
and the update stops.
The variable itself is set to "development-v6". From my understanding the variable is not "null" and the update should be executed (if [ -n "${DOCKER_VERSION}" ]).
BR Christian
pihole -up should work on bare metal, but not Docker.
This should be prevented by
It's strange, that $DOCKER_VERSION is set for you at all.
Please generate a debug log and post the token
I was able to track it down.
/etc/pihole/versions contains the variable
DOCKER_VERSION=development-v6
The file is read in /usr/local/bin/pihole with the line
versionsfile="/etc/pihole/versions"
Due to this the script recognize this environment as an docker environment.
After uncommenting the line in /etc/pihole/versions the script is executed.
For now I'm not able to determine if the file was build/retrieved once during the upgrade from 5 to 6 or if the file was fetched later. Anyway, the update script should make sure that this record does not exist on bare metal setups.
