FTLDNS on Rock64?
If I am going to install a totally new instance of Pi-Hole, do I just create the /etc/pihole directory and then follow the commands above BEFORE i install Pi-hole, or do I just install Pi-hole and then follow the above instructions?
Also, can I just copy over my config files from my "old" pi-hole instance? Mainly my static IP addresses.
I am replacing my RPi board running Pi-hole with a Rock64.
:this:
Yes
Good luck with that! I'm curious if everything works, please do tell us once you come around to set it up.
Thanks!
Will give it a try shortly and report back.
