FTL troubleshooting
FTL is online
FTL failed to start due to failed to creat listening socket for port 53: Address already in use. I can't find in the logs what process is already using port 53
https://tricorder.pi-hole.net/CNq8Uo1M/
Your log shows port 53 is in use by dnsmasq.
[53] is in use by dnsmasq (https://docs.pi-hole.net/main/prerequisites/#ports)
You need to disable dnsmasq and then start FTL.
Thanks not sure how I missed that.
Also is FTL necessary for normal ad blocking, assuming disabling dnsmaq will also disable ad blocking?
The dnsmasq instance showing on your debug log is not related to Pi-hole and it needs to be disabled.
pihole-FTL (also called FTL) is part of Pi-hole and it is necessary.
Thank you I also updated to latest version and all is well. FTL looks to be no longer a separate service on the dashboard.
