FTL offline Ubuntu 16.04.5
FTL to run.
Web interface FTL offline
gwshmg0468
It appears you are running named on port 53, which will conflict with Pi-hole. You need to disable named.
@jacob.salmela that did the trick.
Consider this solved.
