I don't think so because pihole isn't handling DNS the only client it sees is the router itself
Pi-Hole is handling DNS, but not DHCP. Correct?
That is correct
This is just one example of hundreds I have observed recently. Getting so many multiple requests/replys - I know this is way beyond the scope of pihole at this point so I just wanted to thank you all for your time and input.
Not sure if this is something I can blame on the router or what at this point. This seemingly happens for every request
Apr 3 16:54:53 dnsmasq[3591]: forwarded slack.com to 1.0.0.1
Apr 3 16:54:53 dnsmasq[3591]: query[A] slack.com from 192.168.55.1
Apr 3 16:54:54 dnsmasq[3591]: reply slack.com is 13.249.127.2
Apr 3 16:54:54 dnsmasq[3591]: reply slack.com is 13.249.127.119
Apr 3 16:54:54 dnsmasq[3591]: reply slack.com is 13.249.127.9
Apr 3 16:54:54 dnsmasq[3591]: reply slack.com is 13.249.127.84
Apr 3 16:54:57 dnsmasq[3591]: query[A] ssl.gstatic.com from 192.168.55.1
Apr 3 16:54:57 dnsmasq[3591]: forwarded ssl.gstatic.com to 1.0.0.1
Apr 3 16:54:57 dnsmasq[3591]: reply ssl.gstatic.com is 64.233.177.94
What I don't see here is any reply from 1.0.0.1. Perhaps the client keeps asking until they get a reply.
Do you have any firewalls in place that block outgoing DNS traffic from your clients or network?
It seems all the replys come in waves after waves of the queries.
e.g.
Like I mentioned before I have the Luma wifi system, and I did have their network wide "firewall" enabled - I have reached out to their support to clarify a few things but Luma is all but out of business at this point and the Dream Machine Pro I have my eye on is sold out ![]()
slack.com didn't turn up at all in the top domains search we did earlier, so that maybe a coincidence.
Your most frequented domain was debug.opendns.com, with almost 250k queries, followed by the combined numbers for *.lumaops.com at roughly 160k queries.
If you aren't explicitly using OpenDNS's client software, I suspect all of the above to be issued by your Luma devices.
And then I read this:
And indeed, it seems their homepage is gone:
https://lumahome.com/
And nslookup lumaops.com 8.8.8.8 returns:
Server: 8.8.8.8
Address: 8.8.8.8#53
Non-authoritative answer:
*** Can't find lumaops.com: No answer
Seems their server infrastructure is down as well.
I would guess that your Luma devices desperately are trying to contact their home base, and on falling to do so, they try to analyse perceived potential DNS failures through debug.opendns.com.
If you were extremely lucky, other users suffering from the same lack of support may have created a replacement website that could be deployed locally, but I consider that very unlikely.
As a side note, that just supports my personal view that a device for home use should never rely on cloud based software or even storage for operation at all (I customarily cut all new devices from Internet access by default to see if they work and how they behave without).
But that's really not helping you right now, I am afraid.
Once you've verified that your Luma devices are at the heart of this, see if you can disable those cloud features somehow.
If not, getting a new WiFi router may not be your worst option.
Just go for a basic device focused on the job it is supposed to do (i.e providing reasonably fast WiFi with good coverage), and skip on fancy extras - especially if they seem to be cloud based. ![]()
I think you nailed it.
I switched Luma back to Cloudflare for upstream DNS and started manually pointing each device to pihole. Normal and expected behavior.
Unfortunately no way to disable the cloud features with Luma and the wifi is still functional. I am scoping out some different options for my router. Thanks again for your help troubleshooting this.
