FTL online in the interface.
FTL offline in the interface
yvzfu5v0hb
This is my first time here, so I apologise in advance if I've made some foolish error.
Basically, I successfully got Pi-hole running last night and the interface was showing statistics. I had an iOS client using it successfully, too. But then I woke up this morning and woke up the machine, which had slept, and nothing was working. I've spent a few hours reading about possible fixes, but nothing is working.
Strangely, Pi-hole seems to be working on this system, the host (?), but not anywhere else.
Hello @Mcat12 — thanks for the reply. I managed to fix it in the end by uninstalling Unbound which I found was using port 53. At least I think it was Unbound. Something, anyway, was using port 53, but I wasn’t sure what it was until I found this:
After that Pi-hole was fine… But then I had a completely unrelated problem with the network connection to that computer and I had to put the project to one side.
