I have the same issue;
After reboot or power down&up, the admin page shows FTL offline and Unable to connect API .
sudo -u pihole pihole-FTL
is the solution however, I had to enter it to
sudo crontab -e
@reboot ( sleep 30 && sudo -u pihole /usr/bin/pihole-FTL )
sleep 10 wouldnt work.
is there any option to overcome this issue?
Mcat12
2
Do not directly execute FTL, only use the service or systemctl commands.
sudo service pihole-FTL restart
On every reboot I have to execute this command. Is there any other solid solution?
Mcat12
4
What is the output of this command after restarting?
system
Closed
5
