Debug code "i677pwu3b9"
FTL isnt working, and it will not let me reconfigure or update through terminal
Your installation has several problems. From your debug log - Pi-Hole is listening on a different IP range than the gateway.
[✓] IPv4 address(es) bound to the virbr0 interface:
192.168.122.1/24 does not match the IP found in /etc/pihole/setupVars.conf (https://discourse.pi-hole.net/t/use-ipv6-ula-addresses-for-pi-hole/2127)
[i] Default IPv4 gateway: 10.160.1.1
* Pinging 10.160.1.1...
PIHOLE_INTERFACE=virbr0
IPV4_ADDRESS=10.160.1.110/24
Pi-Hole FTL is not running because named (typically BIND9) is on port 53, and pihole-FTL needs that port open.
*:53 named (IPv6)
127.0.0.1:53 named (IPv4)
10.160.1.110:53 named (IPv4)
127.0.0.1:953 named (IPv4)
[::1]:953 named (IPv6)
192.168.122.1:53 named (IPv4)
127.0.0.1:3306 mysqld (IPv4)
*:22 sshd (IPv4)
*:22 sshd (IPv6)
*:80 lighttpd (IPv4)
*:80 lighttpd (IPv6)
You will need to stop the named process and restart FTL. This thread may be of assistance:
https://discourse.pi-hole.net/t/problem-after-updating-lost-connection-to-api/12487/6
