running FTL service
FTL process crashes
8mxhxrihfl
I did also run it through gdb as described here:
interestingly running it via gdb, it does work. I could eliminate one bug through this: a missing /var/run/pihole directory.
also tried to comment out log-queries=extra /etc/dnsmasq.d/01-pihole.conf, but no success.
OS raspian 9.4
[root@jumper ~]# service pihole-FTL restart
[root@jumper ~]# service pihole-FTL status
[root@jumper ~]# ps aux | grep FTL
pihole 15259 58.2 2.7 27488 26112 ? R 13:37 0:06 /usr/bin/pihole-FTL
root 15273 0.0 0.0 4372 540 pts/1 S+ 13:37 0:00 grep FTL
Loaded: loaded (/etc/init.d/pihole-FTL; generated; vendor preset: enabled)
Active: active (exited) since Wed 2018-07-25 13:37:06 CEST; 17s ago
Process: 15229 ExecStop=/etc/init.d/pihole-FTL stop (code=exited, status=0/SUCCESS)
Process: 15235 ExecStart=/etc/init.d/pihole-FTL start (code=exited, status=0/SUCCESS)
Jul 25 13:37:06 jumper.mydomain systemd[1]: Starting LSB: pihole-FTL daemon...
Jul 25 13:37:06 jumper.mydomain pihole-FTL[15235]: Not running
Jul 25 13:37:06 jumper.mydomain su[15245]: Successful su for pihole by root
Jul 25 13:37:06 jumper.mydomain su[15245]: + ??? root:pihole
Jul 25 13:37:06 jumper.mydomain su[15245]: pam_unix(su:session): session opened for user pihole by (uid=0)
Jul 25 13:37:06 jumper.mydomain pihole-FTL[15235]: FTL started!
Jul 25 13:37:06 jumper.mydomain systemd[1]: Started LSB: pihole-FTL daemon.
root 15325 0.0 0.0 4372 552 pts/1 S+ 13:37 0:00 grep FTL
Active: active (exited) since Wed 2018-07-25 13:37:06 CEST; 51s ago
Thank you.
