I keep having the same problem
An error occured while loading the data: Connection refused. Is FTL running?
Root @ pihole: / # cat /var/log/pihole-FTL.log | Nc tricorder.pi-hole.net 9999
Bfu8pns62d
I have pihole -r and -up but still the same
Bfu8pns62d
I moved this to a new topic.
Run pihole -d
for a debug token.
Is done but the log file is big 285.135 kb
What log file, and what is the token?
root@pi:/var/log# pihole -d
::: Beginning Pi-hole debug at Thu Aug 17 10:54:12 EDT 2017!
::: This process collects information from your Pi-hole, and optionally uploads
::: it to a unique and random directory on tricorder.pi-hole.net.
::: NOTE: All log files auto-delete after 48 hours and ONLY the Pi-hole developers
::: can access your data via the given token. We have taken these extra steps to
::: secure your data and will work to further reduce any personal information gathered.
::: Please read and note any issues, and follow any directions advised during this process.
::: ---= Detecting Installed Package Versions:
::: Pi-hole: v3.1.4 (master:v3.1.4-0-gb0ecedd)
::: Pi-hole Dashboard: v3.1 (master:v3.1-0-gf204b71)
::: lighttpd/1.4.33
::: PHP not installed.
REQUIRED FILES MISSING
::: ---= Detecting existence of /etc/pihole/setupVars.conf:
::: File exists, parsing...done and was successfully sourced
::: ---= Detecting installed OS Distribution
::: ---= Checking processor variety
::: ---= Checking IPv6 Stack
::: No IPv6 found on venet0
::: ---= Checking IPv4 Stack
::: IPv4 addresses located on venet0
::: Pinging default IPv4 gateway: ping: unknown host venet0
::: Gateway did not respond.
::: ---= Daemon Process Information
::: Checking http port for lighttpd listener.
::: Correctly configured.
::: Checking domain port for dnsmasq listener.
::: Checking 4711 port for pihole-FTL listener.
::: Failure: IPv4 Port not in use
::: ---= Processes Check
::: Logging status of lighttpd, dnsmasq and pihole-FTL...
/opt/pihole/piholeDebug.sh: line 376: systemctl: command not found
::: ---= Resolver Functions Check (IPv4)
shuf: /etc/pihole/gravity.list: No such file or directory
::: Checking for necessary lighttpd files.
::: ---= Detecting existence of /etc/lighttpd/lighttpd.conf:
::: ---= Detecting existence of /var/log/lighttpd/error.log:
::: ---= Detecting existence of /etc/dnsmasq.conf:
::: ---= Detecting contents of /etc/dnsmasq.d/*:
::: ---= File /etc/dnsmasq.d/01-pihole.conf found
::: Parsing...done
::: ---= File /etc/dnsmasq.d/README found
::: Parsing...done
::: ---= Detecting existence of /etc/pihole/whitelist.txt:
::: /etc/pihole/whitelist.txt not found!
::: ---= Detecting existence of /etc/pihole/blacklist.txt:
::: /etc/pihole/blacklist.txt not found!
::: ---= Detecting existence of /etc/pihole/adlists.list:
::: /etc/pihole/adlists.list not found!
::: ---= Analyzing gravity.list
grep: /etc/pihole/gravity.list: No such file or directory
::: Warning: No gravity.list file found!
::: ---= Analyzing pihole.log
::: ---= Analyzing pihole-FTL.log
::: --= User Action Required =--
::: Try loading a site that you are having trouble with now from a client web browser..
::: (Press CTRL+C to finish logging.)
::: ---= pihole.log
::: Logging will automatically teminate in 60 seconds
::: Finshed debugging!.
::: The debug log can be uploaded to tricorder.pi-hole.net for sharing with developers only.
::: Would you like to upload the log? [y/N]
Did you read the output? We need the debug token, not the program output.
i'm sorry.. but How to get the debug token ?
Type y
in response to the program output:
And it will print out the debug token if it's able to upload it. If it fails to upload, then try copying the file from the Pi-hole and manually uploading it to a paste-bin website.
::: ---=== Your debug token is : 5vgtrskixs Please make a note of it. ===---
How ? Have you seen my logs sir...
Sorry, I've been away for a few days. Please make a new debug token and I'll get back to you (they expire after 48 hours).
