After Upgrading Pihole with sudo PIHOLE_SKIP_OS_CHECK=true pihole -r as the normal procedure fails since a couple of updates I realized that nothing's working anymore, from client side. on the Web Admin GUI I saw that the DNS is not running.
A
pi@raspberrypi:~ $ systemctl status pihole-FTL
Loaded: loaded (/etc/init.d/pihole-FTL; generated; vendor preset: enabled)
Active: failed (Result: exit-code) since Tue 2022-09-06 13:30:59 CEST; 4min 25s ago
Process: 8477 ExecStart=/etc/init.d/pihole-FTL start (code=exited, status=1/FAILURE)
Sep 06 13:30:59 raspberrypi systemd[1]: Starting LSB: pihole-FTL daemon...
Sep 06 13:30:59 raspberrypi pihole-FTL[8477]: Not running
Sep 06 13:30:59 raspberrypi su[8499]: Successful su for pihole by root
Sep 06 13:30:59 raspberrypi su[8499]: + ??? root:pihole
Sep 06 13:30:59 raspberrypi su[8499]: pam_unix(su:session): session opened for user pihole by (uid=0)
Sep 06 13:30:59 raspberrypi pihole-FTL[8477]: /usr/bin/pihole-FTL: /lib/arm-linux-gnueabihf/libc.so.6: version `GLIBC_2.28' not foun
Sep 06 13:30:59 raspberrypi systemd[1]: pihole-FTL.service: Control process exited, code=exited status=1
Sep 06 13:30:59 raspberrypi systemd[1]: Failed to start LSB: pihole-FTL daemon.
Sep 06 13:30:59 raspberrypi systemd[1]: pihole-FTL.service: Unit entered failed state.
Sep 06 13:30:59 raspberrypi systemd[1]: pihole-FTL.service: Failed with result 'exit-code'.
Tried to reconfigure it but with the same error.
After trying to reconfigure it now the webui is also missing.
pi@raspberrypi:~ $ pihole -v
Current Pi-hole version is v5.12
Current AdminLTE version is v5.14.2
pihole-FTL: /lib/arm-linux-gnueabihf/libc.so.6: version GLIBC_2.28' not found (required by pihole-FTL) pihole-FTL: /lib/arm-linux-gnueabihf/libc.so.6: version GLIBC_2.28' not found (required by pihole-FTL)
Invalid Option! Try 'pihole -v --help' for more information.
pi@raspberrypi:~ $ cat /etc/os-release
PRETTY_NAME="Raspbian GNU/Linux 9 (stretch)"
NAME="Raspbian GNU/Linux"
VERSION_ID="9"
VERSION="9 (stretch)"
VERSION_CODENAME=stretch
ID=raspbian
ID_LIKE=debian
HOME_URL="http://www.raspbian.org/"
SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
pi@raspberrypi:~ $ lsb_release -a
No LSB modules are available.
Distributor ID: Raspbian
Description: Raspbian GNU/Linux 9.13 (stretch)
Release: 9.13
Codename: stretch
But even after pihole -r I still get an error with FTL.
Active: failed (Result: exit-code) since Tue 2022-09-06 17:17:23 CEST; 5s ago
Process: 4679 ExecStart=/etc/init.d/pihole-FTL start (code=exited, status=2)
CPU: 102ms
Sep 06 17:17:20 raspberrypi systemd[1]: Starting LSB: pihole-FTL daemon...
Sep 06 17:17:20 raspberrypi pihole-FTL[4679]: Not running
Sep 06 17:17:20 raspberrypi su[4701]: (to pihole) root on none
Sep 06 17:17:20 raspberrypi su[4701]: pam_unix(su:session): session opened for user pihole(uid=999) by (uid=0)
Sep 06 17:17:23 raspberrypi systemd[1]: pihole-FTL.service: Control process exited, code=exited, status=2/INVALIDARG>
Sep 06 17:17:23 raspberrypi systemd[1]: pihole-FTL.service: Failed with result 'exit-code'.
Sep 06 17:17:23 raspberrypi systemd[1]: Failed to start LSB: pihole-FTL daemon.
The WebInterface also says
There was a problem applying your settings.
Debugging information:
PHP error (2): fsockopen(): unable to connect to 127.0.0.1:4711 (Connection refused) in /var/www/html/admin/scripts/pi-hole/php/FTL.php:47
You have another DNS server running on port 53, which prevents pihole-FTL from binding on that port.
*** [ DIAGNOSING ]: Pi-hole diagnosis messages
count last timestamp type message blob1 blob2 blob3 blob4 blob5
1 2022-09-06 17:28:37 DNSMASQ_CONFIG failed to create listening socket for port 53: Die Adresse w
ird bereits verwendet
[✗] udp:127.0.0.1:53 is in use by connmand (https://docs.pi-hole.net/main/prerequisites/#ports)
[✗] tcp:127.0.0.1:53 is in use by connmand (https://docs.pi-hole.net/main/prerequisites/#ports)
You will need to stop and disable connmand.
Your upgrade to Bullseye also enabled predictable interface names.
You may want to run
