FTL.log filled with warnings and errors
Hello, I am not sure what is going on. However, running the current version (v6.0.6 / v6.1).
My lists will occasionally fail to download (connection refused). I don't think this is related but while looking into the issue. I noticed the FTL.log is being spammed with warning and errors.
Uploaded Logs:
https://tricorder.pi-hole.net/chLobBLz/
Any Ideas?
2025-04-14 11:51:35.053 ERROR SQLite3: no such table: info in "SELECT value FROM info WHERE property = 'updated';" (1)
2025-04-14 11:51:35.054 WARNING gravity_updated(): SELECT value FROM info WHERE property = 'updated'; - SQL error prepare: SQL logic error
2025-04-14 11:51:35.599 ERROR SQLite3: no such table: info in "SELECT value FROM info WHERE property = 'abp_domains';" (1)
2025-04-14 11:51:35.600 WARNING gravity_check_ABP_format() - SQL error prepare: SQL logic error
2025-04-14 11:51:35.613 ERROR SQLite3: no such table: info in "SELECT value FROM info WHERE property = 'abp_domains';" (1)
2025-04-14 11:51:35.614 WARNING gravity_check_ABP_format() - SQL error prepare: SQL logic error
2025-04-14 11:51:36.068 ERROR SQLite3: no such table: info in "SELECT value FROM info WHERE property = 'updated';" (1)
2025-04-14 11:51:36.069 WARNING gravity_updated(): SELECT value FROM info WHERE property = 'updated'; - SQL error prepare: SQL logic error
2025-04-14 11:51:37.074 ERROR SQLite3: no such table: info in "SELECT value FROM info WHERE property = 'updated';" (1)
2025-04-14 11:51:37.075 WARNING gravity_updated(): SELECT value FROM info WHERE property = 'updated'; - SQL error prepare: SQL logic error
2025-04-14 11:51:38.081 ERROR SQLite3: no such table: info in "SELECT value FROM info WHERE property = 'updated';" (1)
2025-04-14 11:51:38.082 WARNING gravity_updated(): SELECT value FROM info WHERE property = 'updated'; - SQL error prepare: SQL logic error
2025-04-14 11:51:38.585 ERROR SQLite3: no such table: info in "SELECT value FROM info WHERE property = 'abp_domains';" (1)
2025-04-14 11:51:38.587 WARNING gravity_check_ABP_format() - SQL error prepare: SQL logic error
2025-04-14 11:51:38.597 ERROR SQLite3: no such table: info in "SELECT value FROM info WHERE property = 'abp_domains';" (1)
2025-04-14 11:51:38.598 WARNING gravity_check_ABP_format() - SQL error prepare: SQL logic error
2025-04-14 11:51:39.099 ERROR SQLite3: no such table: info in "SELECT value FROM info WHERE property = 'updated';" (1)
2025-04-14 11:51:39.100 WARNING gravity_updated(): SELECT value FROM info WHERE property = 'updated'; - SQL error prepare: SQL logic error
2025-04-14 11:51:40.004 ERROR SQLite3: no such table: info in "SELECT value FROM info WHERE property = 'updated';" (1)
2025-04-14 11:51:40.005 WARNING gravity_updated(): SELECT value FROM info WHERE property = 'updated'; - SQL error prepare: SQL logic error
2025-04-14 11:51:41.010 ERROR SQLite3: no such table: info in "SELECT value FROM info WHERE property = 'updated';" (1)
After rebooting pihole, the logs were filled with invalid database messages. I ran the gravity update, and the database repaired, and the errors have gone away.
