FTL to not update itself if it is already at the latest version
FTL updates to 5.3.4 every time I check for an update. It is already at that version
tfothr3xn9
tfothr3xn9
Known bug, fix already prepared
Hi yubiuser, thanks for the link however I'm having trouble understanding what to do. Do you know which parameter/code do I type in the cli? thanks
How to solve FTL keep updating ?
Thanks
same, pihole says update available and goes through the full update procedure to only then display the same version.
Current Pi-hole version is v5.2.2.
Current AdminLTE version is v5.2.2.
Current FTL version is v5.3.4.
As noted in the pull request linked above, the Pi-hole code will be changed to fix this problem. The code will first be changed in the development branch, then that change will be incorporated into the next Pi-hole release. There is no schedule or estimated date for the next Pi-hole release.
In the meantime, ignore the error. It does not affect your Pi-hole operation. If you are on the latest release, you are set.
thanks for the assurance update. Good work.
