FTL is offline
Description
I've upgraded Pi-hole 4.x to 5.0 on my Raspberry Pi B. Unfortunately, the web interfaces says that FTL is offline. I've read many articles about similar problem descriptions, and whatever I tried didn't help (start manually, change permission on log files, restart Rasperry, etc.). I'm completely stuck with this problem.
If you are Experiencing issues with a Pi-hole install that has non-standard elements
I'm using a Pi-hole 5.0 standard installation, with apache/php as webserver. I've two Raspberry Pi in my network (Raspberry Pi 2 with IP .18, Raspberry Pi 3 with IP .19), and the problem occurs on both devices. Both should act as DNS (and later as properly configured DHCP server, but DHCP is disabled on both devices at the moment). All of the data in this question is from Raspberry Pi 3 with IP .19.
FTL is online and DNS resolution is working.
FTL is reported offline and DNS resolution is not working.
https://tricorder.pi-hole.net/3st282k2hi
Thanks for your help!
What is the output of the following commands from the Pi terminal:
sudo netstat -nltup | grep 'Proto\|:53 \|:5053 \|:5353 \|:5335 \|:8953 \|:67 \|:80 \|:471'
First of all, thank you for your quick reply!!!
pi@raspberrypi:/var/log $ sudo service pihole-FTL status
ā— pihole-FTL.service - LSB: pihole-FTL daemon
   Active: active (exited) since Sat 2020-05-16 12:09:39 CEST; 1 day 4h ago
  Process: 8712 ExecStart=/etc/init.d/pihole-FTL start (code=exited, status=0/SU
Mai 16 12:09:38 raspberrypi systemd[1]: Starting LSB: pihole-FTL daemon...
Mai 16 12:09:39 raspberrypi pihole-FTL[8712]: Not running
Mai 16 12:09:39 raspberrypi su[8737]: (to pihole) root on none
Mai 16 12:09:39 raspberrypi su[8737]: pam_unix(su:session): session opened for u
Mai 16 12:09:39 raspberrypi pihole-FTL[8712]: dnsmasq: bad DHCP host name at lin
Mai 16 12:09:39 raspberrypi su[8737]: pam_unix(su:session): session closed for u
Mai 16 12:09:39 raspberrypi systemd[1]: Started LSB: pihole-FTL daemon.
pi@raspberrypi:/var/log $ sudo netstat -nltup | grep 'Proto\|:53 \|:5053 \|:5353 \|:5335 \|:8953 \|:67 \|:80 \|:471'
tcp6       0      0 :::80                   :::*                    LISTEN      544/apache2
udp        0      0 224.0.0.251:5353        0.0.0.0:*                           1160/chromium-brows
udp        0      0 224.0.0.251:5353        0.0.0.0:*                           1108/libpepflashpla
udp        0      0 0.0.0.0:5353            0.0.0.0:*                           316/avahi-daemon: r
udp6       0      0 :::5353                 :::*                                316/avahi-daemon: r
This is the problem. The line is truncated, so we can't see the whole error. What is the ouput of these commands from the Pi terminal:
pihole-FTL dnsmasq-test
sudo grep -v '#\|^$' -R /etc/dnsmasq.*
You have an old file in there that appears to be causing problems. Delete it with this:
sudo rm /etc/dnsmasq.conf.old
Also, in /etc/dnsmasq.conf, this line is not needed - edit the file and delete that line.
user=root
After these changes are made, then run sudo service lighttpd restart and see if things are working.
Thank you so much, that was the decisive hint!
I had generated the file 04-pihole-static-dhcp.conf.sav in Microsoft Excel on a windows system (by formula, in order to prevent typos), and this file had Windows line breaks (CR/LF) instead of Linux line breaks (CR).
Could you please tell me where the file 04-pihole-static-dhcp.conf (I had renamed it to 04-pihole-static-dhcp.conf.sav in order to avoid errors due to typos - obviously didn't work out that well) is referred to?
This is used if you are using Pi-hole as DHCP server, and with static leases.
