Probably similar to other people's problems, but haven't found a solution. I don't belive I did an update, upgrade or reboot. I am unsure what caused the problem. I only noticed by accident that PiHole was having problems. My pihole is not the DHCP server, has a fixed IP address. This does not seem to be causing any problems with network devices navigating.
First my FTL was offline and Lost Connection To API was showing. Then I discovered that the DNS was missing so I forced it to 8.8.8.8. That allowed the sudo pihole -r to work and to download its update. DNS servers now show as:
pi@raspberrypi:/var/log $ nslookup www.google.com
Server: 127.0.0.1
Address: 127.0.0.1#53
Non-authoritative answer:
Address: 216.58.205.68
Address: 2a00:1450:4002:807::2004
At this point I have "Lost --- --- API" across the top of the dashboard and all the graphs are spinning circles. I have tried:
- repair and a reconfigure options but neither fix the problem.
- rebooting and restarting services, flushing logs and network tables
The pihole-FTL.log is https://pastebin.com/HYb72C0E
Not sure where else to try. I followed the guide to install screen and gdp. GDP was already installed and screen doesn't seem to do anything. maybe I misunderstood something.
Any ideas what to try next?
Thanks!
Your successful nslookup
from your Pi-hole machine would imply that Pi-hole is working (i.e., if indeed run from your Pi-hole machine, with Pi-hole being the only process listening on port 53).
This would hint at a client browser issue.
Have you tried clearing your browser's cache?
Thanks for the suggestion. Clearing the cache has now showing Lost Connection To API across the top (changed from "---" on the two middle windows). Digging around in the suggestions on the forum, I note that http://192.168.1.xx/admin/api.php?overTimeDataForwards&getForwardDestinationNames returns
Please provide a debug token generated by
Tools > Generate Debug Log
sorry, just to be clear, that nslookup was run from the pihole machine. /etc/resolv.conf has returned to only include localhost (8.8.8.8 has been removed by the machine)
DNS config page is set to only OpenDNS and all other checkboxes are unchecked.
debug token :
https://tricorder.pi-hole.net/47st5p6l0y
You have another DNS server claiming port 53:
*:3128 squid (IPv6)
*:1880 node-red (IPv4)
[53] is in use by named (https://docs.pi-hole.net/main/prerequisites/#ports)
127.0.0.1:953 named (IPv4)
[::1]:953 named (IPv6)
You'd have to disable or uninstall that other DNS server (likely that's BIND/named).
Interesting, seems that when I put webmin onto the pi, it (or I by mistake) started the bind dns server. stopping that has fixed the issue, thank you so much for your time!
You're welcome.
Could you do me a favour and tag an appropriate post as solution?
