FTL failed to start due to failed to bind DHCP server socket: Address already in use
FTL failed to start because you have dnsmasq running on port 53.
[✗] udp:10.42.0.1:53 is in use by dnsmasq (https://docs.pi-hole.net/main/prerequisites/#ports)
[✗] tcp:10.42.0.1:53 is in use by dnsmasq (https://docs.pi-hole.net/main/prerequisites/#ports)
You need to disable dnsmasq. It is using port 53, needed by pihole-FTL.
how do i do that the correct way?
Try using the search option of this forum. If you would have so, you would easily found this thread:
