I tried updating my PiHole, but it says "FTL Engine not installed". I found another post on her with a solution, but I can't edit my resolv.conf file because of permissions. I have no idea what to do here, and I can't log in to the dashboard - a big problem because I need to fix a DHCP issue with a static IP assignment. Please help!
sudo nano /etc/resolv.conf does not work?
That did work, thank you. I apologize, I'm a youngblood when it comes to these.
I successfully edited the file and changed 127.0.0.1 to 8.8.8.8, and ran pihole -r, then pihole -up. Now the system is updated properly. Should I now revert back to 127.0.0.1 in resolv.conf?
You can.
