FTL engine not installed. "Error: URL https://github.com... not found"
It should complete the install.
Stuck with an error:
Error: URL https://github.com/pi-hole/ftl/releases/latest/download/pihole-FTL-arm-linux-gnueabihf not found
[✗] FTL Engine not installed
I apologise for having to ask as this is seemingly a common issue, but I have tried everything I have found recommended and still, with a fresh install of everything, I can't get to to work.
I have edited the resolv.conf file with:
sudo nano /etc/dhcpcd.conf
added "static domain_name_servers=8.8.4.4 8.8.8.8" to the bottom of the file then:
sudo service dhcpcd restart
Then I have checked and the resolv.conf file is now showing 8.8.8.8 and 8.8.4.4.
Being a complete beginner, that is about as far as my troubleshooting abilities go. Any help would be greatly appreciated.
Also, the command:
curl -sSL https://install.pi-hole.net | bash
Now returns "curl: (6) Could not resolve host: install.pi-hole.net". Fine to reinstall everything from the beginning again (as I have already twice) but if there is a better way, please let me know.
Thanks!
From the Pi terminal, what is the output of
dig install.pi-hole.net
pi@pihole:~ $ dig install.pi-hole.net
; <<>> DiG 9.11.5-P4-5.1-Raspbian <<>> install.pi-hole.net
Any idea? Would love to get this working but unfortunately I am stuck and out of ideas. Do you want me to restart everything from the start (I am following this: https://blog.cryptoaustralia.org.au/instructions-for-setting-up-pi-hole/ ) and then run
Tools > Generate Debug Log
I assume from the above initial error that the install did not complete. From what I understand, "pihole -d" is a pihole specific command, so all I get is:
pi@pihole:~ $ pihole -d
-bash: pihole: command not found
That appears to be the case. Let's reset the nameserver for the Pi and run the installer again:
sudo nano /etc/resolv.conf
edit nameserver 127.0.0.1 to nameserver 9.9.9.9 or your preferred third party DNS service, save and exit
So, I was having trouble doing this before due to permissions I think, so I used a method I found somewhere else to edit resolv.conf. So right now my resolv.conf file reads:
# Generated by dhcpcd
# /etc/resolv.conf.head can replace this line
# /etc/resolv.conf.tail can replace this line
The method was by:
then adding
to the bottom of the file.
Happy to start from the beginning again if I have messed something up.
Go ahead and edit the resolv.conf file and then re-run the updater.
Okay great. I had another look at dhcpcd.conf and it seems three lines had been added at some point after I edited the file in the first place. So it had:
interface eth0
        static ip_address=192.168.1.124/24
        static routers=192.168.1.1
appended to the end. I removed "static domain_name_servers=127.0.0.1" and ran
and the resolv.conf file now contains the DNS service I chose (8.8.8.8 and 8.8.4.4).
Long story short, the install worked and I got the below. The web interface loads. Should I be concerned that IPv6 was not configured? I had selected to configure IPv6 during the install.
No, I would not be concerned.
I don't know if that is related to your issue, but I have had the same/this error:
Error: URL https://github.com/pi-hole/ftl/releases/latest/download/pihole-FTL-armv7-linux-gnueabihf not found
It seemed that the github URL has been part of one of my Adlists. Disabling the pihole blocking bad domains/URLs before I was starting "pihole -up" fixed it for me.
I can agree with fricklr: after having disabled my adlists (http://location.of.your.installation/admin/groups-adlists.php) I was able to update FTL. Thanks fricklr for the input!
It is easier and more permanent to whitelist the github.com domain.
Will set that up, thanks for the hint. Though it is obvious, I have not thought about it. Cheers!
I know this is an old thread, but this error seems to have re-appeared - for a different reason.
Error: URL https://github.com/pi-hole/ftl/releases/latest/download/pihole-FTL-armv8-linux-gnueabihf not found
is now being generated - because the page doesn't exist (there seems to be no current Armv8 release of FTL?)
I tried the URL directly in my browser and found nothing. Unless I am misunderstanding something!
I just ran into the same issue... I wonder if this might be because i haven't updated my pihole in a very long time?
Did you do an update or a fresh installation?
I have same problem, and after disable Adlists was update possible.
Thx!
